Bobcat 743 service manual desperately needed and will it turn over if one glow plug is broken off and cant be removed
743needhelp
Can anyone email me a service manual for a 743 because I have one that has been all messed up with wiring undone and wont start but will crank just fine and has a broken off glow plug in the front cylinder. I would greatly appreciate one and dont have the $$$ for one from bobcat disabled vet. So if anyone has one please let me know or email it to me. I have never been on a forum before so if I am not doing this right let me know please. Thanks
743needhelp
Also I cant find a dipstick to check hydraulic fluid on the machine there are two wingnuts on the side of the hydraulic tank where I think there may have been one but someone removed it for some reason. How do I know how much hydraulic fluid to put in it and is there any way to check it regularly.
Sounds like yours had a sight glass in it some one broke I think I have a email OM sent me for my 743 wireing what is your email? But write at instead of @ to keep scamers off
Does it put out white smoke when you try to start it?
743needhelp
norman.bumgarner"at"gmail".com"
Did it have everything to fix and rebuild hydraulics engine, wiring diagrams, etc because this thing is all messed up and I will need as much help as I can get because I am lets say not mechanically inclined but can learn with proper instructions
743needhelp
There is also no wire going to the back glow plug like I think there is suppose to be and the front one is broke off in the block do you have any idea how I can rig it up to still work? Also if the engine cranks but just doesn't turn over is there a good chance I can get it running without having to replace engine? Sorry for all the questions but I need help desperately and really appreciate any help I can get!
Spray some wd40 in the intake and see if it farts
743needhelp
I just bought it and it didnt put out any smoke when it was being cranked by the person I bought it from. They had some things apart and I am trying to put it back together and replace the glow plugs and anything I can do to see if I can get it running. They were cranking it with some type of jumper from the battery to the starter I think with a push button.
743needhelp
How about I emailyou my phone # this will take a bit and my finger is slow
i would appreciate it but can I give you a call in the morning I am about to go to bed. If you have the manual you were refering to I would appreciate that also. Once again I really appreciate you trying to help me I didnt expect to get any help especially so quick.
743needhelp
now is fine also if you prefer because I am desperate for the help and dont want to loose any help you can offer. :>
Ok good nite I will look for the emails from OM and send them to you with my # you have alot going on and it will be easyer over the phone
