Bobcat 843b drive issue
mike13_88
hey guys joined this forum to see if I can get some help on a issue with a bobcat I have purchased. I have tried to make the bobcat drive but it barely moves and growls. put it up on jack stands everything works great goes front back side to side no noises. I am thinking clogged bronze filter? but cant seem to find it? any help to where it is on a 843?
Not sure if you have one but if it is like the 743 it will be on the left side of the pump standing in the bucket there will be a steal block with three hoses comming off the side it will be in the center hose in the steal block
Did some looking and the 843 does have the bronze filter under serial number 14999 if yours has it that is where it should be
M
mike13_88
so are the hoses going out to the left of the block? I cant remember for sure I think that's how it is. Hope I can get to it pretty easy. If I can I'll post pics when I get home thank you.
Serial# 12999 and below part# 6563995 and above that part# 6563920 but they can be cleaned becareful pulling them out there is some kind of sleave that comes out with it mine does not have one but I have a new filter for the first one I will give to someone that send me a prepaid box
Looks easy to get to but can be tight
M
mike13_88
Thank you so it's the block under the cab not the one at the engine bay compartment? There is a ton of hoses under there and I'm not very familiar with hydraulics. I know theres a block under the cab but has a bunch of hoses connected to it I'll try and get a pic later
Under the cab you will see a steal block on the left side of the pump with three hoses going to the left it is the center one
M
mike13_88
Ok I got the cab up and don't see the block with 3 lines there's a block with like 7 lines goin into it beside the pump I don't know how to add a pic off my phone
M
mike13_88
Have you changed the big hydro filter?....... what kind of oil do you use?
I do see a big black hose going to the left straight to the pump. I just got it I fixed a broken hose to the lift filled it up with super s universal oil for the time being just to see if I can get it going the guy I got it from said it pulled to the left wouldn't go right now it don't do anything but growl until you jack it up on stands
Ok did some more home work yours does not have the bronze filter however it shows two hydro filters part# 6599543 and 6598903 need to make sure both are new
Not sure if yours have case drain filters or not ,..........little help here
M
mike13_88
Yea I'm kinda stuck here myself gonna replace both filters they look new but just so I'll know they are clean I just figured the bronze filter was clogged, I guess I try and find new filters wonder which one is hydrostatic drive one under cab or engine bay? The bucket and lift arm works fine
