im not sure what to call it. it is the pin that locks the bottom of the bucket to the machine. the pin that holds the handle lock on. mine has came out and I have no idea what to call it or what part number is. any help would be greatly appreciated.
If you use the link to messicks pick mounting plate from the menu and part #'s and prices are there on the diagram. Prices are about the same as dealer so you know what to expect when you go.Go to a dealer and they should have those parts or be able to get them. You can look at a parts diagram online and get your part numbers
thanks guys for all the help. got it identified and part ordered. should be here tomorrow. thanks again guys for all the help.If you use the link to messicks pick mounting plate from the menu and part #'s and prices are there on the diagram. Prices are about the same as dealer so you know what to expect when you go.
