I have a T200 with a Deutz BF4M1011F with about 4500 hrs. I have run it for about 300 hrs. Before I bought it, I had the compression tested with 2 good cylinders, a passable cylinder and a low cylinder. The biggest deficiency was the range of compressions, which was on the limit of acceptability. By the time the timing belt was replaced, the engine started and ran perfectly, with plenty of power. It fires right up, even if I jump the gun a little on the glow plugs. Sometimes I forget to watch the countdown, but it starts and runs perfectly. The only problem is oil pressure. At idle, engine ward, it's about 23 psi. At 3/4 throttle, it's 32-38 psi. Once, when the RPMs were very low, a low pressure code was set. I cleared it, and haven't had it come back. My plan is to wait for a while before rebuilding the bottom end. I figure that if the top end weren't in pretty good shape, it wouldn't start so well. I think that as long as I am not settling codes, it should be okay to run it, and I'm not doing any real damage. Does that sound right?
