bigmcshawn
- Sep 27, 2014
- 14
Hello I recently picked up a 1999 Bobcat 753 with 1811 HRS, On the day I bought it I decided to take it to my local bobcat dealer for a good look over, before putting it to work. A course they came up with some issues that needed to be fixed! now after paying a large sum of money for a clean bill of health! Everything seems to function as it should with the exception of one problem Hydraulic fluid is blowing out thru the vents in the filler cap! It only seems to happen when lifting and lowering the boom. below is a list of the things the Bobcat dealers fix! Installed new seat bar sensor and bushings. Installed new hydraulic lock stem, o rings, coil and nut. resealed lift & tilt spools inside control valve, new boots with o-rings. No other leaks at this time. Changed engine oil, all filters. changed hydraulic cap, gasket and changed hydraulic oil. I don't know if I should take it back my local bobcat dealer? Please tell me could any of the repairs that they perform have anything to do with my current problem?
