The truck won't re-start when hot and I'm pretty sure the problem is in the circuit that provides voltage to the fuel shutdown solenoid (mounts on injector pump). I've replaced the solenoid and installed new filter before that. It will run all day but after it warms up you shut it down and try to re-start it will turn over but won't fire until it cools down, anywhere from 2 to 3 hours, I crack the line at injector and there's no fuel pressure. I don't have a wiring diagram so thought I would post here to see if anyone has had similar problems. Bobcat Model-S160 Serial-529912344 Any help appreciated, Thanks, Dino54
