Friends, I am posting for an amish neighbor. He has a Bobcat S175 compact skid steer. It is throwing a warning for light 24 on the panel, 3 beeps. Now, he is unsure if this warning preceded or started after the unit was damaged when using a jackhammer attachment to try and remove some rock. While hammering, the right side (when facing the front) arm pin came out and the two sides "racked," bending a bunch of things out of place, as that right side arm raised way up in the air while the left side was still pinned in place. So now, when it is level, one fork is a good 1-2 inches above the other, one side sits a good inch off the rest panel, etc. A few of the hydraulic lines that run along the right arm are slightly impinged/pressed in that lead to the hydro pressure release system. So everything is slightly bent/ajar since that incident. But he is not sure the warning light started before or after. They replaced the solenoids, and a mechanic took a look at it without much help so far. any suggestions/leads/input is appreciated. He is thinking that maybe may just have to trade it in and get a new one given the possible damage/issues, as we don't think if we take it apart to check the right hand side lines, etc. we will be able to get it back together, or at least back together in a way that for the time/parts investment is worth it. John
