Not sure but the stainless steel utility pump from HF works better then I expedited for pumping used motor oil. Just make sure you use garden hose. I tried washer machine hose the first time but it is too small for the volume it needs. HappyNot sure on yours mine is in the front behind the bucket put you can buy a cheap pump that fits on a drill motor or put a hose to a five gallon bucker with the lid on hose close to the bottom then put your shop vac on the top sucking the fluid into the bucket
And still need to open it up and mop out with rags I put a earth magnet in my chain case to keep the metal shavings out of the mixNot sure but the stainless steel utility pump from HF works better then I expedited for pumping used motor oil. Just make sure you use garden hose. I tried washer machine hose the first time but it is too small for the volume it needs. Happy
thank all of you for your replies. Great and helpful info on all replies. I'm sure i got it from here from your answersNot sure on yours mine is in the front behind the bucket put you can buy a cheap pump that fits on a drill motor or put a hose to a five gallon bucker with the lid on hose close to the bottom then put your shop vac on the top sucking the fluid into the bucket
If no hex head on it just grab and pull the center partthank all of you for your replies. Great and helpful info on all replies. I'm sure i got it from here from your answers
There is a drain between the back wheels. There will be a metal plate, remove it to see two plugs on either side. One is the fuel tank, the other is the chain case.If no hex head on it just grab and pull the center part
