this is what is reffered too as a hi to low leak. do em both seal kit about 35 bucks. rember these motors are timed. I have found that if you follow proucdere in manual . youll jack it up . yes find big port to big opening but trick is. have unit off ground and safely supported. bungee both sticks forward. remove fuel shut off wiring and crank unit over. it seems that the intil oil flow is the way they go. if one turns backwards swap the hoses.{BUY THE WAY GUYS IF ANYBODY HAS A BETTER EXPLATION OF THIS PLEASE POST IT } THE S/M IS THE SAME FOR BOTH LEFT AND RIGHT MOTORS, WHICH MAKES NO SENSE TO ME. BIG PORT TO BIG OPENENING. ok that I understand, should be cut and dry. but ive had hundreds of these turn backwards and had to swap hoses. not so easy in some cases, I KNOW SOME HYD HEAD OUT THERE HAS THE ANSWER?
