I guess I'll introduce myself first since I'm new her although I have found a ton of great info on this forums for quite some time I have a bobcat 742 1984 ford 1.6 it started having stalling issues found it to be the starter from other threads here thank you. When I changed the fuel pump I removed the shutoff solenoid from the line as the wire had broke off one terminal so I soldered it and put it back on it started up woo hoo not so fast about 2 minutes later it died then nothing just a click when turning ignition suspected starter had someone give the starter a whack while turning key nothing took out the solenoid still nothing turned the key and held it and smoke coming from the negative terminal on the battery any info ideas brainstorming will be much appreciated also when it ran the power had decreased greatly before it died thanks Brian
