Aftermarket quick attach plate???
Candyman
Trying a different approach with this.Anyone have any other bucket but a gehl on their machine?Having trouble finding one that has the correct angle on the bottom part to match my all-tach gehl setup.Also is the all-tach setup different than the gehl quick attach?Thanks for all the input.This thing is driving me nuts!!
C
Candyman
I wonder if you bent yours some how
Used a strait edge to check but found nothing out of line.Now I did however notice that my lift arm bushings are shot.I have a good amount of slop in the mount.Would this cause the bucket to pop off during back drag?
I have to push mine down hard usally step on them spring loaded try some bailing wire
C
Candyman
Not sure what the baling wire would do?the handles don't pop up when the bucket pops off.Any reasons why mine are loose going down?Thanks for all the advice guys,I appriciate it all
Really hmmmmm is there any ajustment ..........your pins might just be worn down
C
Candyman
Me too can you post some pics
Ok here is the latest in this saga.Called the equipment dealer and he gave me some sound advice to try.I described what was going on and he said it sounded like the top part of the qa on the loader could be worn and not allowing the springs to tension up and hold the pins against the bucket.He said to tack on an 1/8" flat stock to the taper facing the machine.Looks like I'll be breaking out the welder tomorrow.Ill keep everyone posted on the outcome.Did anyone hear of this happening?
C
Candyman
Well I added a shim to the backside of the top mount on the machine and low and behold the bucket didn't fall off.Looks like my mount on the machine is worn a little giving it a little slop.Next step is to try it on the other two attachments.Im keeping my fingers crossed.
