My glow plug countdown has recently started at 29.Never has been that high before, and never been more that 5 in the summer. Now the traction control lock toggles on & off. It will do a lot at lower RPM's. At higher RPM's it will only happen once in a while. I've noticed that when the traction lock toggles on & off the RPM will drop on the display screen, but you cannot hear a drop in the engine. (also, no codes pop up) Any help would be huge. Called Bobcat & they tell me it's the wiring harness or controller. I refuse to believe it. It's garage kept and worked like a champ with no problems. Why out of the blue would the harness or controller go bad?
