I was able to locate a "service" manual for the 743. As Tom suspected, the procedure involves removing the rubber blocks: 1) Disconnect electrical harness. 2) Raise operator cab. 3) Fasten a chain and hoist to the operator cab. 4) Remove the bolts and nuts at the spring blocks. 5) Remove spring blocks. 6) Remove the nuts at the pivot bolts. 7) Tighten the chain hoist and remove the bolts from the pivot bracket. Sounds easy. I guess I can use the 773 to lift the 743 ROPS off and the 743 to lift the 773 ROPS off. I'd have to find a tree or something if I didn't have a spare Bobcat.
Let's try this again with some formatting...
