I have been searching unsuccessfully for days for an answer to this issue on my bobcat. When applying down pressure with my T-180, there is a hesitation where it acts like it is in float mode before it applies more down pressure. For instance, if you have enough down pressure to lift the front of the machine off of the ground and you try to apply more down pressure, it lets the machine down before lifting it back up again. All other hydraulics work strong and there are no codes. Hopefully one of you knowledgeable fellas can help me out here. Thanks!
