Thanks, I found them, 180 degrees opposite the coupler fitting.Parts diagram shows 3, one on the spline coupling and one on each u-joint.
If someone replace the u-joints with different ones the grease fittings may be on the cross instead of the end caps.
Is there any slop if so change them for a hundred bucks will cost alot more if they breakThanks, I found them, 180 degrees opposite the coupler fitting.
Nope, no play in them. By looking at them with a mirror, and just putting my hand back there, it appears the previous owner actually greased them. Working in the auto industry, it was a nice surprise to find something that has actually been maintained, as that seems to be a rarity these days.Is there any slop if so change them for a hundred bucks will cost alot more if they break
Yep lucky manNope, no play in them. By looking at them with a mirror, and just putting my hand back there, it appears the previous owner actually greased them. Working in the auto industry, it was a nice surprise to find something that has actually been maintained, as that seems to be a rarity these days.
