Good Stuff
- Mar 31, 2013
- 21
My t190 seems slow moving forward but fast/normal in reverse?
Yes I raised the cab and looked at those. I have more travel in reverse than I do pushing forward.Check your steering levers where they come out from under the seat. You should have adjustments in the bars under the seat that you can adjust to prevent the levers bottoming out on the frame.
Ensure there are no obstructions at the pump, if none are there, loosen the bolts and slide them forward slightly and see how it goes.Yes I raised the cab and looked at those. I have more travel in reverse than I do pushing forward.
Thank you!Ensure there are no obstructions at the pump, if none are there, loosen the bolts and slide them forward slightly and see how it goes.
