Any codes come up?Check the belt
Or flashing?Any codes come up?
This happened from time to time but when I would turn the ignition off and back again it would be ok . This time it's down for good . The lift light on the side of the seat does not come on. The machine does drive.Check the belt
Sounds like a bad connection check fuses relays switches and groundsThis happened from time to time but when I would turn the ignition off and back again it would be ok . This time it's down for good . The lift light on the side of the seat does not come on. The machine does drive.
Happened from time to time but when I turned the ignition off and back on again it was ok. This time it's off for good. The light for the lift on the panel won't come on. It does drive.Check the belt
Switched all relays around, no change. Working on connections. Thanks for the adviceHappened from time to time but when I turned the ignition off and back on again it was ok. This time it's off for good. The light for the lift on the panel won't come on. It does drive.
Don't forget the seat and seat belt switchSwitched all relays around, no change. Working on connections. Thanks for the advice
Don't see no wires going to the seat or seatbelt except seatbelt which seems to be workingDon't forget the seat and seat belt switch
You have two skids down one has been sitting for awile both electric problems I think you might have a unwanted pet chewing up your wirersDon't see no wires going to the seat or seatbelt except seatbelt which seems to be working
