elbowcarey
- Feb 3, 2012
- 84
(543) I had a little leak so I pulled the top hose off at where the thermostat is to fix it and lost a good amount of coolant, fixed the leak and put the hose back. Now I filled the radiater up again ut when I run the machine Im not sure if coolant is running through that hose I took off is getting hot and theres a light smoke.... What do I do to fix this?
Thanks Craig
Thanks Craig
