dondiesel444
- Mar 8, 2014
- 12
I recently pickup up an '04 ls180 with just shy of 4000 hours, really clean and runs good. when it's cold and I first start the machine, then try to move it wants to stall, like a heavy load on the engine. but once it warms up a bit, it runs fine. just needs to warm up...? here's the issue. when I move the levers the machine wants to quickly lunge forward (or back). it's hard to control it or do anything precise. like the drive motors engage too fast?? I am scarred to get too close to anything b/c it jumps so fast. once moving in forward or revers it's fine, i, no bucking, slipping, anything strange, it's just that initial push where it almost takes off too fast. sometimes seems to be less jerky if I try and take off with the right side than the left, it's still takes off fast. also if I let go of the levers while moving the machine doesn't want to stop, especially the left side. I kinda need to physically pull back on the lever to return it to neutral. very little creep at idle, I expect there to be some with a machine with these hours. the creeping isn't bad at all compared to other machines I've run. when the machine has been run for a while, the left side (which seems to be more problematic than the right) seems to be weak, doesn't even always want to move unless I return the lever to neutral and then go forward again. but on the flip side I remember the other day while digging in a pile of dirt the left side would keep spinning and even stalled the motor b/c like I said before all I did was let go of the lever and not actually pull it back to neutral. so maybe once it's hot it gets worse? also seems to not have as much power in forward, reverse seems fine. I haven't a whole lot of time on this machine, but I have a lot of dirt to move with it in the next few weeks. I want it running 100%, I know I'm not used to it being new to me, but something just doesn't seem right about it. I've run skid steers all my life I used to have a L785 and a LX865 10+ years ago. This machine just has a strange feel to it. again the engine runs great. again i understand it's old and has a lot of hours on it, and it's not gonna run like a new one. any help is appreciated, before it goes to the dealer for a big repair bill...
or I just need to live with it...
