Wild-bobcat S205
- Feb 17, 2014
- 30
Kind of annoying but this forum doesn't allow line breaks on the text. Bobcat Loader error codes: LOADER XX-XX Codes Bobcat Controller Code Description 01-16 Air Filter Not Connected 01-17 Air Filter Plugged 02-16 Hydraulic Implement Filter Not Connected 02-17 Hydraulic Implement Filter Plugged 03-09 Battery Voltage Low 03-10 Battery Voltage High 03-11 Battery Voltage Extremely High 03-14 Battery Voltage Extremely Low 03-22 Battery Voltage Out of Range Low 04-09 Engine Oil Pressure Low 04-14 Engine Oil Pressure Extremely Low 04-15 Engine Oil Pressure In Shutdown 04-21 Engine Oil Pressure Out Of Range High 04-22 Engine Oil Pressure Out Of Range Low 05-09 Hydraulic Charge Pressure Low 05-10 Hydraulic Charge Pressure High 05-11 Hydraulic Charge Pressure Extremely High 05-14 Hydraulic Charge Pressure Extremely Low 05-15 Hydraulic Charge Pressure In Shutdown 05-21 Hydraulic Charge Pressure Out Of Range High 05-22 Hydraulic Charge Pressure Out Of Range Low 06-10 Engine Speed High 06-11 Engine Speed Extremely High 06-13 Engine Speed No Signal 06-15 Engine Speed In Shutdown 06-18 Engine Speed Out Of Range 07-10 Hydraulic Oil Temperature High 07-11 Hydraulic Oil Temperature Extremely High 07-15 Hydraulic Oil Temperature In Shutdown 07-21 Hydraulic Oil Temperature Out Of Range High 07-22 Hydraulic Oil Temperature Out Of Range Low 08-10 Engine Coolant Temperature High 08-11 Engine Coolant Temperature Extremely High 08-15 Engine Coolant Temperature In Shutdown 08-21 Engine Coolant Temperature Out Of Range High 08-22 Engine Coolant Temp Out Of Range Low 09-09 Fuel Level Low 09-21 Fuel Level Out Of Range High 09-22 Fuel Level Out Of Range Low 10-16 Hydraulic Charge Filter Not Connected 10-17 Hydraulic Charge Filter Plugged 11-05 Seat Bar Sensor Short To Battery 11-06 Seat Bar Sensor Short To Ground 12-21 Front Auxiliary Thumb Paddle Switch Out Of Range High 12-22 Front Auxiliary Thumb Paddle Switch Out Of Range Low 12-23 Front Auxiliary PWM Switch Not In Neutral 13-05 Fuel Shutoff Hold Coil Short To Battery 13-06 Fuel Shutoff Hold Solenoid Short To Ground 13-07 Fuel Shutoff Hold Solenoid Open Circuit 14-02 Fuel Shutoff Pull Coil Error On 14-03 Fuel Shutoff Pull Coil Error Off 15-02 Traction Lock Pull Coil Error On 15-03 Traction Lock Pull Coil Error Off 16-05 Traction Lock Hold Coil Short To Battery 16-06 Traction Lock Hold Coil Short To Ground 16-07 Traction Lock Hold Solenoid Open Circuit 17-05 Hydraulic Lock Solenoid Short To Battery 17-06 Hydraulic Lock Solenoid Short To Ground 17-07 Hydraulic Lock Solenoid Open Circuit 18-05 Spool Lock Coil Short To Battery 18-06 Spool Lock Coil Short To Ground 18-07 Spool Lock Coil Open Circuit 19-02 Bucket Position Solenoid Error On 19-03 Bucket Position Solenoid Error Off 20-02 Two Speed Solenoid Error On 20-03 Two Speed Solenoid Error Off 21-02 Glow Plug Error On 21-03 Glow Plug Error Off 22-02 Starter Error On 22-03 Starter Error Off 23-02 Rear Base Solenoid Error On 23-03 Rear Base Solenoid Error Off 24-02 Rear Rod Solenoid Error On Bobcat Controller (Cont'd) Code Description 24-03 Rear Rod Solenoid Error Off 25-02 Rear Auxiliary Relief Solenoid Error On 25-03 Rear Auxiliary Relief Solenoid Error Off 26-02 Front Base Solenoid Error On 26-03 Front Base Solenoid Error Off 27-02 Front Rod Solenoid Error On 27-03 Front Rod Solenoid Error Off 28-02 Diverter Solenoid Error On 28-03 Diverter Solenoid Error Off 29-02 High Flow Solenoid Error On 29-03 High Flow Solenoid Error Off 30-28 Controller Memory Failure 31-28 Interrupted Power 33-23 Bobcat Controller Not Programmed 34-04 Deluxe Panel In Error 35-02 Hydraulic Fan Error On 35-03 Hydraulic Fan Error Off 36-48 Multiple ACDs Present 37-02 Two Speed Make-up Solenoid Error On 37-03 Two Speed Make-up Error Off 37-07 Two Speed Secondary Solenoid Open Circuit 39-04 Left Joystick Switches In Error 39-12 Left CAN Joystick Thumb Paddle Switch Not In Neutral 39-13 Left CAN Joystick Grip No Communication 39-16 Left CAN Joystick Base No Communication 39-28 Left CAN Joystick Internal Failure 39-48 Left CAN Joystick Multiple 40-04 Right Joystick Switches In Error 40-12 Right CAN Joystick Thumb Paddle Switch Not In Neutral 40-13 Right CAN Joystick Grip No Communication 40-16 Right CAN Joystick Base No Communication 40-28 Right CAN Joystick Internal Failure 40-48 Right CAN Joystick Multiple 41-09 Alternator Low Output 41-10 Alternator Voltage High 41-11 Alternator Voltage Extremely High 44-02 Horn Relay Error On 44-03 Horn Relay Error Off 45-02 Right Blinker Relay Error On 45-03 Right Blinker Relay Error Off 46-02 Left Blinker Relay Error On 46-03 Left Blinker Relay Error Off 47-21 8 Volt Sensor Supply Out Of Range High 47-22 8 Volt Sensor Supply Out Of Range Low 48-02 Front Light Relay Error On 48-03 Front Light Relay Error Off 49-02 Rear Light Relay Error On 49-03 Rear Light Relay Error Off 60-21 Rear Auxiliary Control Out Of Range High 60-22 Rear Auxiliary Control Out Of Range Low 60-23 Rear Auxiliary Control Not In Neutral 64-02 Switched Power Relay Error On 64-03 Switched Power Relay Error Off 74-72 Main Bobcat Controller In Boot Code 76-73 Left Display Panel System Rx In Error 77-48 Key Switch Multiple 78-74 Door / Transport Lock Open / Active 80-02 ACD/RACD Output "A" Error On 80-03 ACD/RACD Output "A" Error Off 81-02 ACD/RACD Output "B" Error On 81-03 ACD/RACD Output "B" Error Off 82-02 ACD/RACD Output "C" Error On 82-03 ACD/RACD Output "C" Error Off 83-02 ACD/RACD Output "D" Error On 83-03 ACD/RACD Output "D" Error Off 84-02 ACD/RACD Output "E" Error On 84-03 ACD/RACD Output "E" Error Off 85-02 ACD/RACD Output "F" Error On 85-03 ACD/RACD Output "F" Error Off 86-02 ACD/RACD Output "G" Error On 86-03 ACD/RACD Output "G" Error Off 87-02 ACD/RACD Output "H" Error On 87-03 ACD/RACD Output "H" Error Off Update June 2009 LOADER XX-XX Codes ACS Controller Code Description 32-04 No Communication From ACS Controller 32-23 ACS Controller Not Calibrated 32-24 ACS Controller Calibration Performed 32-25 ACS Controller Calibration Failure 32-31 ACS / AHC Tilt Actuator Fault 32-32 AHC Tilt Actuator Wiring Fault 32-33 AHC Tilt Handle Wiring Fault 32-34 ACS / AHC Tilt Actuator Not In Neutral 32-35 ACS / AHC Tilt Handle / Pedal Not In Neutral, SJC Right Joystick X-axis Not In Neutral 32-36 ACS / AHC Lift Actuator Fault 32-37 AHC Lift Actuator Wiring Fault 32-38 AHC Lift Handle Wiring Fault 32-39 ACS / AHC Lift Actuator Not In Neutral 32-40 ACS / AHC Lift Handle / Pedal Not In Neutral, SJC Right Joystick Y-axis Not In Neutral 32-41 AHC Controller No Communication 32-49 ACS Lift Actuator Short To Ground (Error Off) 32-50 ACS Tilt Actuator Short To Ground (Error Off) 32-51 ACS Lift Actuator Short To Battery (Error On) 32-52 ACS Tilt Actuator Short To Battery (Error On) 32-53 ACS Lift Handle / Pedal Short To Ground, SJC Right Joystick Y-axis Short To Ground 32-54 ACS Tilt Handle / Pedal Short To Ground, SJC Right Joystick X-axis Short To Ground 32-55 ACS Lift Handle / Pedal Short To Battery, SJC Right Joystick Y-axis Short To Battery 32-56 ACS Tilt Handle Pedal Short To Battery, SJC Right Joystick X-axis Short To Battery 32-57 ACS Lift Actuator Reduced Performance 32-58 ACS Tilt Actuator Reduced Performance 32-59 ACS Lift Actuator Wrong Direction 32-60 ACS Tilt Actuator Wrong Direction 32-61 ACS Handle Lock Short To Ground 32-62 ACS Handle Lock Short To Battery 32-63 ACS Pedal Lock Short To Ground 32-64 ACS Pedal Lock Short To Battery 32-65 ACS Sensor Supply Voltage Out Of Range 32-66 ACS Battery Voltage Out Of Range 32-67 ACS Operating Mode Switch Flipped While Operating 32-68 ACS Lift Handle Information Error 32-70 Right Joystick Y-axis Out Of Range Low 32-71 Right Joystick Y-axis Out Of Range High 32-75 Interrupted Un-switched Power 32-76 CAN Joystick Information Error 32-97 ACS Controller Programmed 40-05 Right CAN Joystick X-axis Not In Neutral 40-07 Right CAN Joystick Y-axis Not In Neutral AWS-SJC Controller Code Description 38-01 CAN Joystick Information Error 38-02 Remote Control Information Error 38-03 Actuator Calibration Failure 38-04 AWS/SJC Controller No Communication 38-05 Left Analog Joystick X-Axis Not In Neutral 38-06 Right Analog Joystick X-Axis Not In Neutral 38-07 Left Analog Joystick Y-Axis Not In Neutral 38-08 Right Joystick Y-Axis Not In Neutral 38-09 Operating Mode Switch Short to Ground or Battery 38-10 Actuator Calibration Performed 38-11 AWS / SJC Lift Actuator Not In Neutral 38-12 AWS / SJC Tilt Actuator Not In Neutral 38-13 AWS / SJC Lift Actuator Fault 38-14 AWS / SJC Tilt Actuator Fault 38-15 AWS / SJC Right Wheel Speed Fault 38-16 AWS / SJC Left Wheel Speed Fault 38-17 AWS / SJC Tilt Actuator Reduced Performance 38-18 AWS / SJC Lift Actuator Reduced Performance 38-19 Left Joystick X-Axis Out Of Range High 38-20 Right Joystick X-Axis Out Of Range High 38-21 Left Joystick Y-Axis Out Of Range High 38-22 Right Joystick Y-Axis Out Of Range High 38-23 Right Front Steering Sensor Out Of Range High 38-24 Left Front Steering Sensor Out Of Range High 38-25 Right Rear Steering Sensor Out Of Range High AWS-SJC Controller (Cont'd) Code Description 38-26 Left Rear Steering Sensor Out Of Range High 38-27 AWS / SJC Lift Actuator Out Of Range High 38-28 AWS / SJC Tilt Actuator Out Of Range High 38-29 Left Joystick X-Axis Out Of Range Low 38-30 Right Joystick X-axis Out Of Range Low 38-31 Left Joystick Y-Axis Out Of Range Low 38-32 Right Joystick Y-Axis Out Of Range Low 38-33 Right Front Steering Sensor Out Of Range Low 38-34 Left Front Steering Sensor Out Of Range Low 38-35 Right Rear Steering Sensor Out Of Range Low 38-36 Left Rear Steering Sensor Out Of Range Low 38-37 5 Volt Sensor Supply 1 Out Of Range Low 38-38 5 Volt Sensor Supply 2 Out Of Range Low 38-39 AWS / SJC Lift Actuator Short To Ground 38-40 AWS / SJC Tilt Actuator Short To Ground 38-41 Tilt Actuator Wrong Direction 38-42 Lift Actuator Wrong Direction 38-43 Left Forward Drive Solenoid Error On 38-44 Left Reverse Drive Solenoid Error On 38-45 Right Forward Drive Solenoid Error On 38-46 Right Reverse Drive Solenoid Error On 38-47 Right Front Steering Solenoid Error On 38-48 Left Front Steering Solenoid Error On 38-49 Right Rear Steering Solenoid Error On 38-50 Left Rear Steering Solenoid Error On 38-51 Pressure Control Steering Solenoid Error On 38-52 Backup Alarm Error On 38-53 Left Forward Drive Solenoid Error Off 38-54 Left Reverse Drive Solenoid Error Off 38-55 Right Forward Drive Solenoid Error Off 38-56 Right Reverse Drive Solenoid Error Off 38-57 Right Front Extend Steering Solenoid Error Off 38-58 Right Front Retract Steering Solenoid Error Off 38-59 Left Front Extend Steering Solenoid Error Off 38-60 Left Front Retract Steering Solenoid Error Off 38-61 Right Rear Extend Steering Solenoid Error Off 38-62 Right Rear Retract Steering Solenoid Error Off 38-63 Left Rear Extend Steering Solenoid Error Off 38-64 Left Rear Retract Steering Solenoid Error Off 38-65 Pressure Control Steering Solenoid Error Off 38-66 Backup Alarm Short To Ground 38-67 No Communication From Bobcat Controller 38-68 Wheel Angle Sensors Not Calibrated 38-69 AWS / SJC Controller Not Calibrated 38-70 Interrupted Power 38-71 Battery Voltage Out Of Range 38-72 Drive Pump Not Calibrated 38-73 Operating Mode Switch Pressed While Operating 38-74 Right Wheel Speed Uncommanded Motion 38-75 Left Wheel Speed Uncommanded Motion 38-85 5.0 Volt Sensor Supply 1 Out Of Range High 38-86 Sensor Supply 2 Out Of Range High 38-87 Right Front Steering Solenoid Error 38-88 Left Front Steering Solenoid Error 38-89 Right Rear Steering Solenoid Error 38-90 Left Rear Steering Solenoid Error 38-93 Right Speed Sensor Unresponsive 38-94 Left Speed Sensor Unresponsive 38-95 Left Speed Sensor Reverse Direction 38-96 Right Speed Sensor Reverse Direction 38-97 AWS/SJC Controller Programmed 38-98 Controller In Drive Calibration Mode 38-99 AWS Controller In Wheel Position Calibration Mode 39-05 Left CAN Joystick X-axis Not In Neutral 39-07 Left CAN Joystick Y-axis Not In Neutral 40-05 Right CAN Joystick X-axis Not In Neutral 40-07 Right CAN Joystick Y-axis Not In Neutral Update June 2009 LOADER XX-XX Codes SSL Drive / Drive Plus Controller Code Description 39-05 Left CAN Joystick X-axis Not In Neutral 39-07 Left CAN Joystick Y-axis Not In Neutral 75-01 CAN Joystick Information Error 75-04 No Communication From Drive Controller 75-05 Left Joystick X-axis Not In Neutral Left (ISO Mode Only) 75-07 Left Joystick Y-axis Not In Neutral 75-08 Right Joystick Y-axis Not In Neutral (H-Pattern Only) 75-09 Operating Mode Switch Short To Ground Or Battery 75-13 Right Front Wheel Unresponsive 75-14 Left Front Wheel Unresponsive 75-15 Right Rear Wheel Unresponsive 75-16 Left Rear Wheel Unresponsive 75-17 Left Swash Plate Not In Neutral 75-18 Right Swash Plate Not In Neutral 75-19 Left Joystick X-axis Out Of Range High 75-21 Left Joystick Y-axis Out Of Range High 75-23 Right Front Steering Sensor Out Of Range High 75-24 Left Front Steering Sensor Out Of Range High 75-25 Right Rear Steering Sensor Out Of Range High 75-26 Left Rear Steering Sensor Out Of Range High 75-27 Left Swash Plate Out Of Position 75-28 Right Swash Plate Out Of Position 75-29 Left Joystick X-axis Out Of Range Low 75-31 Left Joystick Y-axis Out Of Range Low 75-33 Right Front Steering Sensor Out Of Range Low 75-34 Left Front Steering Sensor Out Of Range Low 75-35 Right Rear Steering Sensor Out Of Range Low 75-36 Left Rear Steering Sensor Out Of Range Low 75-37 5.0 Volt Sensor Supply 1 Out Of Range Low 75-38 5 Volt Sensor Supply 2 Out Of Range Low 75-39 Left Swash Plate Sensor Out Of Range High 75-40 Left Swash Plate Sensor Out Of Range Low 75-41 Right Swash Plate Sensor Out Of Range High 75-42 Right Swash Plate Sensor Out Of Range Low 75-43 Left Forward Drive Solenoid Error On 75-44 Left Reverse Drive Solenoid Error On 75-45 Right Forward Drive Solenoid Error On 75-46 Right Reverse Drive Solenoid Error On 75-47 Right Front Extend Steering Solenoid Error On 75-48 Left Front Extend Steering Solenoid Error On 75-49 Right Rear Extend Steering Solenoid Error On 75-50 Left Rear Extend Steering Solenoid Error On 75-51 Pressure Control Steering Solenoid Error On 75-52 Backup Alarm Error On 75-53 Left Forward Drive Solenoid Error Off 75-54 Left Reverse Drive Solenoid Error Off 75-55 Right Forward Drive Solenoid Error Off 75-56 Right Reverse Drive Solenoid Error Off 75-57 Right Front Extend Steering Solenoid Error Off 75-58 Right Front Retract Steering Solenoid Error Off 75-59 Left Front Extend Steering Solenoid Error Off 75-60 Left Front Retract Steering Solenoid Error Off 75-61 Right Rear Extend Steering Solenoid Error Off 75-62 Right Rear Retract Steering Solenoid Error Off 75-63 Left Rear Extend Steering Solenoid Error Off 75-64 Left Rear Retract Steering Solenoid Error Off 75-65 Pressure Control Steering Solenoid Error Off 75-66 Backup Alarm Error Off 75-67 No Communication From Bobcat Controller 75-68 Angle Sensors Not Calibrated 75-69 Battery Voltage Out Of Range High 75-70 Interrupted Power 75-71 Battery Voltage Out Of Range Low 75-72 Drive Pump – Not Calibrated 75-73 Operating Mode Switch Flipped While Operating 75-74 Right Wheel Speed Uncommanded Motion 75-75 Left Wheel Speed Uncommanded Motion 75-76 No Communication From ACS Controller 75-77 Left Speed Sensor Out Of Range High 75-78 Right Speed Sensor Out Of Range High 75-79 Left Speed Sensor Out Of Range Low 75-80 Right Speed Sensor Out Of Range Low 75-81 Right Front Retract Steering Solenoid Error On SSL Drive / Drive Plus Controller Code Description 75-82 Left Front Retract Steering Solenoid Error On 75-83 Right Rear Retract Steering Solenoid Error On 75-84 Left Rear Retract Steering Solenoid Error On 75-85 5.0 Volt Sensor Supply 1 Out Of Range High 75-86 Sensor Supply 2 Out Of Range High 75-87 Software Update Required 75-88 Switched Power Error On 75-91 Left Swash Plate Sensor - Reversed 75-92 Right Swash Plate Sensor - Reversed 75-93 Unresponsive Right Speed Sensor 75-94 Unresponsive Left Speed Sensor 75-95 Left Speed Sensor Reverse Direction 75-96 Right Speed Sensor Reverse Direction 75-97 Drive / Drive Plus Controller Programmed 75-98 Controller In Calibration Mode 75-99 Drive Plus Controller In Wheel Position Calibration Mode Update June 2009 LOADER ALPHA-NUMERIC CODES Gateway Controller Code Description M0116 Air Filter Not Connected M0117 Air Filter Plugged M0216 Hydraulic Implement Filter Not Connected M0217 Hydraulic Implement Filter Plugged M0309 Battery Voltage Low M0310 Battery Voltage High M0311 Battery Voltage Extremely High M0314 Battery Voltage Extremely Low M0322 Battery Voltage Out Of Range Low M0409 Engine Oil Pressure Low M0414 Engine Oil Pressure Extremely Low M0415 Engine Oil Pressure In Shutdown M0421 Engine Oil Pressure Out Of Range High M0422 Engine Oil Pressure Out Of Range Low M0509 Hydraulic Charge Pressure Low M0510 Hydraulic Charge Pressure High M0511 Hydraulic Charge Pressure Extremely High M0514 Hydraulic Charge Pressure Extremely Low M0515 Hydraulic Charge Pressure In Shutdown M0521 Hydraulic Charge Pressure Out Of Range High M0522 Hydraulic Charge Pressure Out Of Range Low M0610 Engine Speed High M0611 Engine Speed Extremely High M0613 Engine Speed No Signal M0615 Engine Speed In Shutdown M0618 Engine Speed Out Of Range M0710 Hydraulic Oil Temperature High M0711 Hydraulic Oil Temperature Extremely High M0715 Hydraulic Oil Temperature In Shutdown M0721 Hydraulic Oil Temperature Out Of Range High M0722 Hydraulic Oil Temperature Out Of Range Low M0810 Engine Coolant Temperature High M0811 Engine Coolant Temperature Extremely High M0815 Engine Coolant Temperature In Shutdown M0821 Engine Coolant Temperature Out Of Range High M0822 Engine Coolant Temperature Out Of Range Low M0909 Fuel Level Low M0921 Fuel Level Out Of Range High M0922 Fuel Level Out Of Range Low M1016 Hydraulic Charge Filter Not Connected M1017 Hydraulic Charge Filter Plugged M1121 Seatbar Sensor Out Of Range High M1122 Seatbar Sensor Out Of Range Low M1305 Fuel Shutoff Hold Coil Short To Battery M1306 Fuel Shutoff Hold Coil Short To Ground M1307 Fuel Shutoff Hold Coil Open Circuit M1402 Fuel Pull Output Error On M1403 Fuel Pull Output Error Off M1407 Fuel Pull Output Open Circuit M1428 Fuel Pull Output Controller Failure M1502 Traction Lock Pull Output Error On M1503 Traction Lock Pull Output Error Off M1507 Traction Lock Pull Output Open Circuit M1528 Traction Lock Pull Output Controller Failure M1605 Traction Lock Hold Solenoid Short To Battery M1606 Traction Lock Hold Solenoid Short To Ground M1607 Traction Lock Hold Solenoid Open Circuit M1705 Hydraulic Lock Valve Solenoid Short To Battery M1706 Hydraulic Lock Valve Solenoid Short To Ground M1707 Hydraulic Lock Valve Solenoid Open Circuit M1732 Hydraulic Lock Valve Solenoid Over Current M1805 Lift Spool Lock Short To Battery M1806 Lift Spool Lock Short To Ground M1807 Lift Spool Lock Open Circuit M1832 Lift Spool Lock Solenoid Over Current M2005 Two Speed Solenoid Short To Battery M2006 Two Speed Solenoid Short To Ground M2007 Two Speed Solenoid Open Circuit M2032 Two Speed Solenoid Over Current M2102 Glow Plug Output Error On M2103 Glow Plug Output Error Off M2107 Glow Plug Output Open Circuit Gateway Controller (Cont'd) Code Description M2128 Glow Plug Output Controller Failure M2202 Starter Output Error On M2203 Starter Output Error Off M2207 Starter Output Open Circuit M2228 Starter Output Controller Failure M2302 Starter Relay Error On M2303 Starter Relay Error Off M2307 Starter Relay Open Circuit M2402 Fuel Pull Relay Error On M2403 Fuel Pull Relay Error Off M2407 Fuel Pull Output Open Circuit M2502 Traction Lock Relay Error On M2503 Traction Lock Pull Relay Error Off M2507 Traction Lock Output Open Circuit M2602 Glow Plug Relay Error On M2603 Glow Plug Relay Error Off M2607 Glow Plug Output Open Circuit M2805 Auxiliary Interlock Output Short To Battery M2806 Auxiliary Interlock Output Short To Ground M2807 Auxiliary Interlock Output Open Circuit M3028 Controller Memory Failure M3128 Interrupted Power Failure M3204 ACS In Error M3304 Deluxe Panel No Communication M3323 Gateway Controller Not Programmed M3404 Deluxe Panel No Communication M3505 Hydraulic Fan Solenoid Error On M3506 Hydraulic Fan Solenoid Error Off M3507 Hydraulic Fan Solenoid Open Circuit M3532 Hydraulic Fan Solenoid Over Current M3648 Multiple ACDs Present (Attachment Control Device) M3705 Two Speed Secondary Error On M3706 Two Speed Secondary Error Off M3707 Two Speed Secondary Solenoid Open Circuit M3732 Two Speed Secondary Over Current M4109 Alternator Low Output M4110 Alternator Voltage High M4404 Auxiliary Controller No Communication M4621 5 Volt Sensor Supply Out Of Range High M4622 5 Volt Sensor Supply Out Of Range Low M4721 8 Volt Sensor Supply Out Of Range High M4722 8 Volt Sensor Supply Out Of Range Low M4802 Front Light Relay Error On M4803 Front Light Relay Error Off M4807 Front Light Output Open Circuit M4902 Rear Light Relay Error On M4903 Rear Light Relay Error Off M4907 Rear Light Output Open Circuit M5002 Front Light Output Error On M5003 Front Light Output Error Off M5007 Front Light Output Open Circuit M5028 Front Light Output Controller Failure M5102 Rear Light Output Error On M5103 Rear Light Output Error Off M5107 Rear Light Output Open Circuit M5128 Front Light Output Controller Failure M5202 PTOL (Press To Operate Loader)Switch Error On M5221 PTOL Switch Out Of Range High M5222 PTOL Switch Out Of Range Low M5305 PTOL Led Short To Battery M5306 PTOL Led Short To Ground M5405 Tilt Spool Lock Short To Battery M5406 Tilt Spool Lock Short To Ground M5407 Tilt Spool Lock Open Circuit M5432 Tilt Spool Lock Over Current M6402 Switched Power Relay Error On M6403 Switched Power Relay Error Off M6407 Switched Power Output Open Circuit M7002 Switched Power Output Error On M7003 Switched Power Output Error Off M7007 Switched Power Output Open Circuit M7028 Switched Power Output Controller Failure Updated June 2009 LOADER ALPHA-NUMERIC CODES Gateway Controller (Cont'd) Code Description M7304 Remote Control Receiver No Communication M7423 Gateway Controller Not Programmed M7472 Gateway Controller In Boot Code M7504 Drive Controller No Communication M7604 Left Display Panel No Communication M7748 Key Switch Multiple M7974 Door Open Auxiliary Controller Code Description H1221 Front Auxiliary Thumb Paddle Switch Out Of Range High H1222 Front Auxiliary Thumb Paddle Switch Out Of Range Low H1224 Front Auxiliary Thumb Paddle Switch Not In Neutral H1324 Rear Auxiliary Thumb Paddle Switch Not In Neutral H2305 Rear Base Solenoid Shorted to Battery H2306 Rear Base Solenoid Short To Ground H2307 Rear Base Solenoid Open Circuit H2332 Rear Base Solenoid Over Current H2405 Rear Rod Solenoid Short To Battery H2406 Rear Rod Solenoid Short To Ground H2407 Rear Rod Solenoid Open Circuit H2432 Rear Rod Solenoid Over Current H2605 Front Base Solenoid Short To Battery H2606 Front Base Solenoid Short To Ground H2607 Front Base Solenoid Open Circuit H2632 Front Base Solenoid Over Current H2705 Front Rod Solenoid Short To Battery H2706 Front Rod Solenoid Short To Ground H2707 Front Rod Solenoid Open Circuit H2732 Front Rod Solenoid Over Current H2805 Diverter Solenoid Short To Battery H2806 Diverter Solenoid Short To Ground H2807 Diverter Solenoid Open Circuit H2905 High Flow Solenoid Short To Battery H2906 High Flow Solenoid Short To Ground H2907 High Flow Solenoid Open Circuit H2932 High Flow Solenoid Over Current H3028 Auxiliary Controller Memory Failure H3128 Interrupted Power Failure H3648 Multiple ACDs Present (Attachment Control Device) H3913 Left CAN Joystick Grip No Communication H3916 Left CAN Joystick Base No Communication H3928 Left CAN Joystick Internal Failure H3948 Left CAN Joystick Multiple H4013 Right CAN Joystick Grip No Communication H4016 Right CAN Joystick Base No Communication H4028 Right CAN Joystick Internal Failure H4048 Right CAN Joystick Multiple H4302 Horn Relay Error On H4303 Horn Relay Error Off H4423 Auxiliary Controller Not Programmed H4502 Right Blinker Error On H4503 Right Blinker Error Off H4602 Left Blinker Error On H4603 Left Blinker Error Off H4721 8 Volt Sensor Supply Out Of Range High H4722 8 Volt Sensor Supply Out Of Range Low H7404 Gateway Controller No Communication H7604 Left Display Panel No Communication ACD Controller Code Description A8002 ACD/RACD Output "A" Error On A8003 ACD/RACD Output "A" Error Off A8102 ACD/RACD Output "B" Error On A8103 ACD/RACD Output "B" Error Off A8202 ACD/RACD Output "C" Error On A8203 ACD/RACD Output "C" Error Off A8302 ACD/RACD Output "D" Error On A8303 ACD/RACD Output "D" Error Off A8402 ACD/RACD Output "E" Error On A8403 ACD/RACD Output "E" Error Off A8502 ACD/RACD Output "F" Error On A8503 ACD/RACD Output "F" Error Off A8602 ACD/RACD Output "G" Error On A8603 ACD/RACD Output "G" Error Off A8702 ACD/RACD Output "H" Error On A8703 ACD/RACD Output "H" Error Off ACS Controller Code Description W3223 ACS Controller Not Calibrated W3224 ACS Controller Calibration Successful W3225 ACS Controller Calibration Failure W3231 ACS Tilt Actuator Fault W3234 ACS Tilt Actuator Not In Neutral W3235 ACS Tilt Handle/Pedal Not In Neutral W3236 ACS Lift Actuator Fault W3239 ACS Lift Actuator Not In Neutral (ACS Only) W3240 ACS Lift Handle/Pedal Not In Neutral W3249 ACS Lift Actuator Short To Ground (Error Off) (ACS Only) W3250 ACS Tilt Actuator Short To Ground (Error Off) W3251 ACS Lift Actuator Short To Battery (Error On) (ACS Only) W3252 ACS Tilt Actuator Short To Battery (Error On) W3253 ACS Lift Handle/Pedal Short To Ground W3254 ACS Tilt Handle/Pedal Short To Ground W3255 ACS Lift Handle/Pedal Short To Battery W3256 ACS Tilt Handle/Pedal Short To Battery W3257 ACS Lift Actuator Reduced Performance W3258 ACS Tilt Actuator Reduced Performance W3259 ACS Lift Actuator Wrong Direction (ACS Only) W3260 ACS Tilt Actuator Wrong Direction W3261 ACS Handle Lock Short To Ground W3262 ACS Handle Lock Short To Battery W3263 ACS Pedal Lock Short To Ground W3264 ACS Pedal Lock Short To Battery W3265 ACS Sensor Supply Voltage Out Of Range (ACS Only) W3266 ACS Battery Voltage Out Of Range (ACS Only) W3267 ACS Operating Mode Switch Flipped While Operating W3275 Interrupted Un-switched Power W3276 CAN Joystick Information Error W3297 ACS Controller Programmed W3905 Left CAN Joystick X-axis Not In Neutral W4005 Right CAN Joystick X-axis Not In Neutral W4007 Right CAN Joystick Y-axis Not In Neutral Left Hand Panel Controller Code Description L0102 Lights Button Error On L0202 High Flow Button Error On L0302 Auxiliary Button Error On L0402 Information Button Error On L7404 Gateway Controller No Communication L7672 Left Hand Panel Programming Error Updated June 2009 LOADER ALPHA-NUMERIC CODES SSL Drive / Drive Plus Controller Code Description D3905 Left CAN Joystick X Axis Not in Neutral D3907 Left CAN Joystick Y-axis Not In Neutral D4007 Right CAN Joystick Y-axis Not In Neutral D7501 CAN Joystick Information Error D7509 Operating Mode Switch Short To Ground Or Battery D7513 Right Front Wheel Unresponsive D7514 Left Front Wheel Unresponsive D7515 Right Rear Wheel Unresponsive D7516 Left Rear Wheel Unresponsive D7517 Left Swash Plate Not In Neutral D7518 Right Swash Plate Not In Neutral D7523 Right Front Steering Sensor Out Of Range High D7524 Left Front Steering Sensor Out Of Range High D7525 Right Rear Steering Sensor Out Of Range High D7526 Left Rear Steering Sensor Out Of Range High D7527 Left Swash Plate Out Of Position D7528 Right Swash Plate Out Of Position D7533 Right Front Steering Sensor Out Of Range Low D7534 Left Front Steering Sensor Out Of Range Low D7535 Right Rear Steering Sensor Out Of Range Low D7536 Left Rear Steering Sensor Out Of Range Low D7537 5.0 Volt Sensor Supply 1 Out Of Range Low D7538 5 Volt Sensor Supply 2 Out Of Range Low D7539 Left Swash Plate Sensor Out Of Range High D7540 Left Swash Plate Sensor Out Of Range Low D7541 Right Swash Plate Sensor Out Of Range High D7542 Right Swash Plate Sensor Out Of Range Low D7543 Left Forward Drive Solenoid Error On D7544 Left Reverse Drive Solenoid Error On D7545 Right Forward Drive Solenoid Error On D7546 Right Reverse Drive Solenoid Error On D7547 Right Front Extend Steering Solenoid Error On D7548 Left Front Extend Steering Solenoid Error On D7549 Right Rear Extend Steering Solenoid Error On D7550 Left Rear Extend Steering Solenoid Error On D7551 Pressure Control Steering Solenoid Error On D7552 Backup Alarm Error On D7553 Left Forward Drive Solenoid Error Off D7554 Left Reverse Drive Solenoid Error Off D7555 Right Forward Drive Solenoid Error Off D7556 Right Reverse Drive Solenoid Error Off D7557 Right Front Extend Steering Solenoid Error Off D7558 Right Front Retract Steering Solenoid Error Off D7559 Left Front Extend Steering Solenoid Error Off D7560 Left Front Retract Steering Solenoid Error Off D7561 Right Rear Extend Steering Solenoid Error Off D7562 Right Rear Retract Steering Solenoid Error Off D7563 Left Rear Extend Steering Solenoid Error Off D7564 Left Rear Retract Steering Solenoid Error Off D7565 Pressure Control Steering Solenoid Error Off D7566 Backup Alarm Error Off D7567 No Communication From Gateway Controller D7568 Angle Sensors Not Calibrated D7569 Battery Voltage Out Of Range High D7570 Interrupted Power D7571 Battery Voltage Out Of Range Low D7572 Drive Pump – Not Calibrated D7573 Operating Mode Switch Flipped While Operating D7574 Right Wheel Speed Uncommanded Motion D7575 Left Wheel Speed Uncommanded Motion D7577 Left Speed Sensor Out Of Range High D7578 Right Speed Sensor Out Of Range High D7579 Left Speed Sensor Out Of Range Low D7580 Right Speed Sensor Out Of Range Low D7581 Right Front Retract Steering Solenoid Error On D7582 Left Front Retract Steering Solenoid Error On D7583 Right Rear Retract Steering Solenoid Error On D7584 Left Rear Retract Steering Solenoid Error On D7585 5.0 Volt Sensor Supply 1 Out Of Range High D7586 Sensor Supply 2 Out Of Range High D7587 Software Update Required D7588 Switched Power Stuck On SSL Drive / Drive Plus Controller (Cont'd) Code Description D7591 Left Swash Plate Sensor - Reversed D7592 Right Swash Plate Sensor - Reversed D7593 Unresponsive Right Speed Sensor D7594 Unresponsive Left Speed Sensor D7595 Left Speed Sensor Reverse Direction D7596 Right Speed Sensor Reverse Direction D7597 Drive / Drive Plus Controller Programmed D7598 Drive / Drive Plus Controller In Calibration Mode D7599 Drive Plus Controller In Wheel Position Calibration Mode Updated June 2009 EXCAVATOR XX-XX CODES Excavator Display Controller Code Description 02-16 Hydraulic/Hydrostatic Filter Not Connected 02-17 Hydraulic/Hydrostatic Filter Plugged 03-09 Battery Voltage Low 03-10 Battery Voltage High 03-11 Battery Voltage Extremely High 03-14 Battery Voltage Extremely Low 03-15 Battery Voltage In Shutdown 03-22 Battery Voltage Out Of Range Low 04-14 Engine Oil Pressure Extremely Low 04-15 Engine Oil Pressure Shutdown Level 05-09 Travel Pilot Pressure Low 05-14 Travel Pilot Pressure Extremely Low 05-15 Travel Pilot Pressure In Shutdown 05-21 Travel Pilot Pressure Out Of Range High 05-22 Travel Pilot Pressure Out Of Range Low 06-10 Engine Speed High 06-11 Engine Speed Extremely High 06-13 Engine Speed No Signal 06-15 Engine Speed In Shutdown 06-18 Engine Speed Out Of Range High 07-10 Hydraulic Oil Temperature High 07-11 Hydraulic Oil Temperature Extremely High 07-15 Hydraulic Oil Temperature In Shutdown 07-21 Hydraulic Oil Temperature Out Of Range High 07-22 Hydraulic Oil Temperature Out Of Range Low 08-10 Engine Coolant Temperature High 08-11 Engine Coolant Temperature Extremely High 08-15 Engine Coolant Temperature In Shutdown 08-21 Engine Coolant Temperature Out Of Range High 08-22 Engine Coolant Temperature Out Of Range Low 09-21 Fuel Level Out Of Range High 09-22 Fuel Level Out Of Range Low 12-21 Auxiliary PWM Switch Out Of Range High 12-22 Auxiliary PWM Switch Out Of Range Low 12-23 Auxiliary PWM Switch Not In Neutral 13-05 Fuel Shutoff Hold Solenoid Short To Battery 13-06 Fuel Shutoff Hold Solenoid Short To Ground 13-07 Fuel Shutoff Hold Solenoid Open Circuit 14-02 Fuel Shutoff Pull Solenoid Error On 14-03 Fuel Shutoff Pull Solenoid Error Off 20-02 Two Speed Error On 20-03 Two Speed Error Off 21-02 Glow Plug Error On 21-03 Glow Plug Error Off 22-02 Starter Error On 22-03 Starter Error Off 26-02 Front Base Solenoid Error On 26-03 Front Base Solenoid Error Off 26-05 Front Base PWM Short to Battery 26-06 Front Base PWM Short to Ground 26-07 Front Base PWM Open Circuit 27-02 Front Rod Solenoid Error On 27-03 Front Rod Solenoid Error Off 27-05 Front Rod PWM Short to Battery 27-06 Front Rod PWM Short to Ground Excavator Display Controller Code Description 20-03 Two Speed Error Off 21-02 Glow Plug Error On 21-03 Glow Plug Error Off 22-02 Starter Error On 22-03 Starter Error Off 26-02 Front Base Solenoid Error On 26-03 Front Base Solenoid Error Off 26-05 Front Base PWM Short to Battery 26-06 Front Base PWM Short to Ground 26-07 Front Base PWM Open Circuit 27-02 Front Rod Solenoid Error On 27-03 Front Rod Solenoid Error Off 27-05 Front Rod PWM Short to Battery 27-06 Front Rod PWM Short to Ground 27-07 Front Rod PWM Open Circuit 28-02 Diverter Solenoid Error On 28-03 Diverter Solenoid Error Off 31-28 Interrupted Power Failure 33-23 Main Controller Not Programmed 35-05 Hydraulic Fan Short To Battery 35-06 Hydraulic Fan Short To Ground 62-04 Load Moment Monitoring In Error 63-05 Console Switch Short To Battery 63-06 Console Switch Short To Ground 64-05 Switched Power Relay Short To Battery 64-06 Switched Power Relay Short To Ground 64-07 Switched Power Relay Open Circuit 65-05 Workgroup Lockout Solenoid Short To Battery 65-06 Workgroup Lockout Solenoid Short To Ground 65-07 Workgroup Lockout Solenoid Open Circuit 66-05 Travel Pilot Pressure Short To Battery 66-06 Travel Pilot Pressure Short To Ground 66-07 Travel Pilot Pressure Open Circuit Updated June 2009 EXCAVATOR ALPHA-NUMERIC CODES Excavator Display Controller Code Description C0216 Hydraulic/Hydrostatic Filter Not Connected C0217 Hydraulic/Hydrostatic Filter Plugged C0309 Battery Voltage Low C0310 Battery Voltage High C0311 Battery Voltage Extremely High C0314 Battery Voltage Extremely Low C0315 Battery Voltage In Shutdown C0322 Battery Voltage Out Of Range Low C0414 Engine Oil Pressure Extremely Low C0415 Engine Oil Pressure In Shutdown C0610 Engine Speed High C0611 Engine Speed Extremely High C0613 Engine Speed No Signal C0615 Engine Speed In Shutdown C0618 Engine Speed Out Of Range High C0710 Hydraulic Oil Temperature High C0711 Hydraulic Oil Temperature Extremely High C0715 Hydraulic Oil Temperature In Shutdown C0721 Hydraulic Oil Temperature Out Of Range High C0722 Hydraulic Oil Temperature Out Of Range Low C0810 Engine Coolant Temperature High C0811 Engine Coolant Temperature Extremely High C0815 Engine Coolant Temperature In Shutdown C0821 Engine Coolant Temperature Out Of Range High C0822 Engine Coolant Temperature Out Of Range Low C0921 Fuel Level Out Of Range High C0922 Fuel Level Out Of Range Low C1221 Auxiliary PWM Switch Out Of Range High C1222 Auxiliary PWM Switch Out Of Range Low C1223 Auxiliary PWM Switch Not In Neutral C1305 Fuel Shutoff Hold Solenoid Short To Battery C1306 Fuel Shutoff Hold Solenoid Short To Ground C1307 Fuel Shutoff Hold Solenoid Open Circuit C1402 Fuel Shutoff Pull Solenoid Error On C1403 Fuel Shutoff Pull Solenoid Error Off C2005 Two Speed Error On C2006 Two Speed Error Off C2102 Glow Plug Error On C2103 Glow Plug Error Off C2202 Starter Error On C2203 Starter Error Off C2305 Offset Base Solenoid Short To Battery C2306 Offset Base Solenoid Short to Ground C2307 Offset Base Solenoid Open Circuit C2405 Offset Rod Solenoid Short To Battery C2406 Offset Rod Solenoid Short to Ground C2407 Offset Rod Solenoid Open Circuit C2505 Offset Return Short To Battery C2506 Offset Return Short To Ground C2507 Offset Return Open Circuit C2605 Auxiliary Base Solenoid Short to Battery C2606 Auxiliary Base Solenoid Short to Ground C2607 Auxiliary Base Solenoid Open Circuit C2705 Auxiliary Rod Solenoid Short to Battery C2706 Auxiliary Rod Solenoid Short to Ground C2707 Auxiliary Rod Solenoid Open Circuit C2802 Hydraulic Exchange Error On Excavator Display Controller (Cont'd) Code Description C2803 Hydraulic Exchange Error Off C3028 Controller Memory Failure C3128 Interrupted Power Failure C3323 Main Controller Not Programmed C3397 Main Controller Programmed C4021 Angle Blade Control Out Of Range High C4022 Angle Blade Control Out Of Range Low C4023 Angle Blade Control Not In Neutral C4105 Angle Blade Base Solenoid Short to Battery C4106 Angle Blade Base Solenoid Short to Ground C4107 Angle Blade Base Solenoid Open Circuit C4205 Angle Blade Rod Solenoid Short to Battery C4206 Angle Blade Rod Solenoid Short to Ground C4207 Angle Blade Rod Solenoid Open Circuit C4321 Load Sense Pressure Out Of Range High C4322 Load Sense Pressure Out Of Range Low C4516 Throttle Controller No Communication C6021 Offset Control Out Of Range High C6022 Offset Control Out Of Range Low C6023 Offset Control Not In Neutral C6204 Load Moment Monitoring In Error C6305 Console Switch Short To Battery C6306 Console Switch Short To Ground C6405 Switched Power Relay Short To Battery C6406 Switched Power Relay Short To Ground C6407 Switched Power Relay Open Circuit C6505 Workgroup Lockout Solenoid Short To Battery C6506 Workgroup Lockout Solenoid Short To Ground C6507 Workgroup Lockout Solenoid Open Circuit Engine Controller Code Description E0105 Throttle Actuator Short To Battery E0106 Throttle Actuator Short To Ground E0107 Throttle Actuator Open Circuit E0123 Throttle Controller Not Calibrated E0321 5 Volt Sensor Supply Out Of Range High E0322 5 Volt Sensor Supply Out Of Range Low E0421 Engine Speed Control Dial Out Of Range High E0422 Engine Speed Control Dial Out Of Range Low E0521 Throttle Actuator Feedback Out Of Range High E0522 Throttle Actuator Feedback Out Of Range Low Updated June 2009 E60/E80 E-ECU CONTROLLER CODES E60/E80 E-ECU Controller Code Description P0117 Engine Coolant Temperature Sensor Out Of Range Low P0118 Engine Coolant Temperature Sensor Out Of Range High P0119 Engine Coolant Temperature Sensor Intermittent Connection P0122 Accelerator Sensor Out Of Range Low P0123 Accelerator Sensor Out Of Range High P0124 Accelerator Sensor Intermittent Connection P0217 Engine Coolant Temperature High P0340 Engine Speed Sensor No Signal P0562 Battery Voltage Low P0563 Battery Voltage High P0605 E-ECU Internal FlashROM Checksum Error A (Main Software) P0634 E-ECU Temperature Sensor High P0642 5 Volt Sensor Supply Out Of Range Low P0643 5 Volt Sensor Supply Out Of Range High P0668 E-ECU Temperature Sensor Out Of Range Low P0669 E-ECU Temperature Sensor Out Of Range High P1202 Rack Position Sensor Out Of Range Low P1203 Rack Position Sensor Out of Range High P1211 Rack Actuator Solenoid Stuck P1212 Rack Actuator Solenoid Undercurrent P1213 Rack Actuator Solenoid Overcurrent P1222 Rack Actuator Relay Error On P1223 Rack Actuator Relay Error Off P1224 Rack Actuator Relay Intermittent Connection P1232 Preheat relay Error On P1233 Preheat relay Error Off P1234 Preheat Relay Intermittent Connection P1242 CSD Solenoid Valve Error On P1243 CSD Solenoid Valve Error Off P1244 CSD Solenoid Valve Intermittent Connection P1402 EGR Valve Phase A Error On P1403 EGR Valve Phase A Error Off P1412 EGR Valve Phase B Error On P1413 EGR Valve Phase B Error Off P1422 EGR Valve Phase C Error On P1423 EGR Valve Phase C Error Off P1432 EGR Valve Phase D Error On P1433 EGR Valve Phase D Error Off P1605 E-ECU Internal FlashROM Checksum Error B (Main Software) P1606 E-ECU Internal FlashROM Checksum Error C (Main Software) P1644 5 Volt Sensor Supply Intermittent Connection P1664 E-ECU Temperature Sensor Intermittent Connection TOOLCAT XX-XX CODES Toolcat Display Controller Code Description 02-16 Hydraulic Charge Filter Not Connected 02-17 Hydraulic Charge Filter Plugged 03-09 Battery Voltage Low 03-10 Battery Voltage High 03-11 Battery Voltage Extremely High 03-14 Battery Voltage Extremely Low 03-15 Battery Voltage In Shutdown 03-22 Battery Voltage Out Of Range Low 04-14 Engine Oil Pressure Extremely Low 04-15 Engine Oil Pressure Shutdown Level 06-10 Engine Speed High 06-11 Engine Speed Extremely High 06-13 Engine Speed No Signal 06-15 Engine Speed In Shutdown 06-18 Engine Speed Out Of Range High 07-10 Hydraulic Oil Temperature High 07-11 Hydraulic Oil Temperature Extremely High 07-15 Hydraulic Oil Temperature In Shutdown 07-21 Hydraulic Oil Temperature Out Of Range High 07-22 Hydraulic Oil Temperature Out Of Range Low 08-10 Engine Coolant Temperature High 08-11 Engine Coolant Temperature Extremely High 08-15 Engine Coolant Temperature In Shutdown 08-21 Engine Coolant Temperature Out Of Range High 08-22 Engine Coolant Temperature Out Of Range Low 09-09 Fuel Level Low 09-21 Fuel Level Out Of Range High 09-22 Fuel Level Out Of Range Low 12-21 Auxiliary PWM Switch Out Of Range High 12-22 Auxiliary PWM Switch Out Of Range Low 12-23 Auxiliary PWM Switch Not In Neutral 13-05 Fuel Shutoff Hold Solenoid Short To Battery 13-06 Fuel Shutoff Hold Solenoid Short To Ground 13-07 Fuel Shutoff Hold Solenoid Open Circuit 14-02 Fuel Shutoff Pull Solenoid Error On 14-03 Fuel Shutoff Pull Solenoid Error Off 18-05 Spool Lock Short To Battery 18-06 Spool Lock Short To Ground 18-07 Spool Lock Open Circuit 20-02 Two Speed Error On 20-03 Two Speed Error Off 21-02 Glow Plug Error On 21-03 Glow Plug Error Off 22-02 Starter Error On 22-03 Starter Error Off 26-02 Front Base Output Error On 26-03 Front Base Output Error Off 27-02 Front Rod Solenoid Error On 27-03 Front Rod Solenoid Error Off 28-02 Diverter Solenoid Error On 28-03 Diverter Solenoid Error Off 29-02 High Flow Solenoid Error On 29-03 High Flow Solenoid Error Off 30-28 Controller Memory Failure 31-28 Interrupted Power Failure 33-23 Main Controller Not Programmed 35-05 Two Speed Fan Short To Battery 35-06 Two Speed Fan Short To Ground 36-48 ACD Multiple Controllers Present 63-05 TICS Sensor Short To Battery 63-06 TICS Switch Short To Ground 64-05 Switched Power Relay Short To Battery 64-06 Switched Power Relay Short To Ground 64-07 Switched Power Relay Open Circuit 65-05 Workgroup Lockout Solenoid Short To Battery 65-06 Workgroup Lockout Solenoid Short To Ground 65-07 Workgroup Lockout Solenoid Open Circuit 67-05 Bobtach Short To Battery 67-06 Bobtach Short To Ground 69-05 Operator Presence Relay Short To Battery 69-06 Operator Presence Relay Short To Ground 69-07 Operator Presence Relay Open Circuit Toolcat Drive Controller Code Description 50-01 Drive Pedal Out Of Range High 50-02 Drive Pedal Out Of Range Low 50-03 Travel Pedal Not Calibrated 50-04 Brake Pedal Out Of Range High 50-05 Brake Pedal Out Of Range Low 50-06 Brake Pedal Not Calibrated 50-07 Travel Direction Control Lever No Signal 50-08 Travel Direction Control Lever Multiple Inputs 50-09 Front Wheel Speed Sensor Out Of Range High 50-10 Front Wheel Speed Sensor Out Of Range Low 50-11 Rear Wheel Speed Sensor Out Of Range High 50-12 Rear Wheel Speed Sensor Out Of Range Low 50-13 Front Wheel Speed Sensor No Signal 50-14 Rear Wheel Speed Sensor No Signal 50-15 Dual Wheel Speed Sensor Fault 50-19 Swash Plate Sensor Out Of Range High 50-20 Swash Plate Sensor Out Of Range Low 50-24 Battery Voltage Over Voltage 50-25 Battery Voltage Under Voltage 50-26 Interrupted Power 50-27 5.0 Volt Sensor Supply 1 Out Of Range High 50-28 5.0 Volt Sensor Supply 1 Out Of Range Low 50-29 5.0 Volt Sensor Supply 2 Out Of Range High 50-30 5.0 Volt Sensor Supply 2 Out Of Range Low 50-31 Front Drive PWM Solenoid Error On 50-32 Forward Drive Coil Short To Battery 50-33 Front Drive PWM Solenoid No Signal 50-34 Front Drive PWM Solenoid Not Calibrated 50-35 Front Drive Forward Solenoid Error On 50-36 Front Drive Forward Solenoid Error Off 50-37 Front Drive Reverse Solenoid Error On 50-38 Front Drive Reverse Solenoid Error Off 50-39 Rear Drive PWM Solenoid Error On 50-40 Reverse Drive Coil Short To Battery 50-41 Rear Drive PWM Solenoid No Signal 50-42 Rear Drive PWM Solenoid Not Calibrated 50-43 Rear Drive Forward Solenoid Error On 50-44 Rear Drive Forward Solenoid Error Off 50-45 Rear Drive Reverse Solenoid Error On 50-46 Rear Drive Reverse Solenoid Error Off 50-47 Two Speed Error Off 50-48 Two Speed Error On 50-49 Brake Solenoid Error On 50-50 Brake Solenoid Error Off 50-51 Brake Solenoid No Signal 50-52 Brake Lights Short To Battery 50-53 Brake Lights Short To Ground 50-54 Differential Lock Error On 50-55 Differential Lock Error Off 50-56 CAN Communications Fault 50-57 Drive Controller Not Calibrated 50-59 Front Wheel Speed Sensor Missing Pulses 50-60 Remote Hydraulics Short To Battery 50-61 Remote Hydraulics Short To Ground 50-63 Front Angle Sensor Calibration Error 50-65 Auxiliary Base Coil Short To Ground or Open Circuit 50-66 Rear Angle Sensor Calibration Error 50-67 Front Drive Forward No Signal 50-68 Front Drive Reverse No Signal 50-69 Rear Drive Forward No Signal 50-70 Rear Drive Reverse No Signal 50-72 Fan Coil Short To Ground 50-74 Throttle Sensor Channel A Out Of Range Low 50-75 Throttle Sensor Channel B Out Of Range High 50-76 Throttle Sensor Channel B Out Of Range Low 50-77 Auxiliary Diverter Error On 50-78 Auxiliary Diverter Error Off 50-80 PTO Speed Sensor Out Of Range High 50-81 PTO Speed Sensor Out Of Range Low 50-82 PTO Speed Sensor Open Circuit 50-99 In Calibration Mode Updated June 2009 VersaHANDLER XX-XX CODES VersaHANDLER Display Controller Code Description 02-16 Hydraulic Charge Filter Not Connected 02-17 Hydraulic Charge Filter Plugged 03-09 Battery Voltage Low 03-10 Battery Voltage High 03-11 Battery Voltage Extremely High 03-14 Battery Voltage Extremely Low 03-15 Battery Voltage in Shutdown 03-22 Battery Voltage Out of Range Low 04-14 Engine Oil Pressure Extremely Low 04-15 Engine Oil Pressure in Shutdown 06-10 Engine Speed High 06-11 Engine Speed Extremely High 06-13 Engine Speed No Signal 06-15 Engine Speed In Shutdown 06-18 Engine Speed Out of Range 07-10 Hydraulic Oil Temperature High 07-11 Hydraulic Oil Temperature Extremely High 07-15 Hydraulic Oil Temperature In Shutdown 07-21 Hydraulic Oil Temperature Out Of Range High 07-22 Hydraulic Oil Temperature Out Of Range Low 08-10 Engine Coolant Temperature High 08-11 Engine Coolant Temperature Extremely High 08-15 Engine Coolant Temperature In Shutdown 08-21 Engine Coolant Temperature Out Of Range High 08-22 Engine Coolant Temperature Out of Range Low 09-21 Fuel Level Out Of Range High 09-22 Fuel Level Out Of Range Low 13-05 Fuel Shutoff Hold Solenoid Short To Battery 13-06 Fuel Shutoff Hold Solenoid Short To Ground 13-07 Fuel Shutoff Hold Solenoid Open Circuit 14-02 Fuel Shutoff Pull Solenoid Error On 14-03 Fuel Shutoff Pull Solenoid Error Off 21-02 Glow Plug Error On 21-03 Glow Plug Error Off 22-02 Starter Error On 22-03 Starter Error Off 30-28 Controller Memory Failure 31-28 Interrupted Power 33-23 Constant Data Not Calibrated 36-48 ACD (Attachment Control Device) Multiple Controllers Present 63-05 Operator Presence Sensor Short To Battery 63-06 Operator Presence Sensor Short to Ground 64-05 Switched Power Relay Short To Battery 64-06 Switched Power Relay Short To Ground 64-07 Switched Power Relay Open Circuit 65-05 Joystick Lockout Short To Battery 65-06 Joystick Lockout Short To Ground 65-07 Joystick Lockout Open Circuit 70-28 Brake Pressure Failure 77-48 Key Switch Multiple VersaHANDLER Drive Controller Code Description 50-02 Extend / Retract Control Out of Range High 50-03 Extend/Retract Control Out of Range Low 50-04 Extend/Retract Control Not In Neutral 50-05 Auxiliary Control Out of Range High 50-06 Auxiliary Control Out of Range Low 50-07 Auxiliary Control Not In Neutral 50-14 Inching Control Out of Range High 50-15 Inching Control Out of Range Low 50-16 Inching Control Not Calibrated 50-20 Boom Pressure Out Of Range High 50-21 Boom Pressure Out Of Range Low 50-23 Drive Controller Not Programmed 50-24 Stability Valve Error On 50-25 Stability Valve Error Off 50-26 Interrupted Power 50-28 FNR No Inputs Active 50-29 FNR More than One Input Active 50-30 Rear Light Relay Error On 50-31 Rear Light Relay Error Off 50-33 Passive Brake Valve Error On 50-34 Passive Brake Valve Error Off 50-36 Brake Light Relay Error On 50-37 Brake Light Relay Error Off 50-42 Secondary Auxiliary Hydraulic Valve Error On 50-43 Secondary Auxiliary Hydraulic Valve Error Off 50-45 Extend/Retract Base Error On 50-46 Extend/Retract Base Error Off 50-48 5 Volt Sensor Supply 1 Out Of Range Low 50-49 5 Volt Sensor Supply 1 Out Of Range High 50-50 5 Volt Sensor Supply 2 Out of Range Low 50-51 5 Volt Sensor Supply 2 Out of Range High 50-54 Switched Battery Over Voltage 50-55 Switched Battery Under Voltage 50-56 CAN Communication Fault 50-57 Drive Controller Not Calibrated 50-58 CAN RPM Message Stale 50-60 Drive Pump Forward Error On 50-61 Drive Pump Forward Error Off 50-63 Drive Pump Reverse Error On 50-64 Drive Pump Reverse Error Off 50-66 Extend/Retract Rod Error On 50-67 Extend/Retract Rod Error Off 50-69 Auxiliary Hydraulics Base Error On 50-70 Auxiliary Hydraulics Base Error Off 50-72 Auxiliary Hydraulics Rod Error On 50-73 Auxiliary Hydraulics Rod Error Off 50-78 Boom Float Relay Error On 50-79 Boom Float Relay Error Off 50-80 Two Speed Relay Error On 50-81 Two Speed Relay Error Off 50-82 EEPROM Error
