If you need a place to store the set you aren't using, I can hold them for you. I bought mine with the 18" tracks. I just couldn't see not needing the larger footprint for my needs...Never mind guess this was to tuff of a question I bought both
now that you have some time on them which track do you recommend. I am looking at a t590, salesman says 12.5, others are saying wider is better. I tear out a lot of concrete drives and sand sub-grade gets me stuck with wheeled unit.If you need a place to store the set you aren't using, I can hold them for you. I bought mine with the 18" tracks. I just couldn't see not needing the larger footprint for my needs...
Always go with a wider track, they help to keep rocks and dirt fron reaching the rollers.now that you have some time on them which track do you recommend. I am looking at a t590, salesman says 12.5, others are saying wider is better. I tear out a lot of concrete drives and sand sub-grade gets me stuck with wheeled unit.
