2012 T650 Stalls When Moving
Wright1822
MY T650 has been stalling or nearly stalling when it is moving. It happens in forward and reverse. The machine is all electronic joystick. It seems like the problem is much worse the colder it gets, but that could just be a coincidence. The problem happens with no load and when it is not pushing dirt. When moving the motor seems to bog down so I will let off the joystick and it revs back up. Sometimes it continues to bog down even after I let off the joystick and usually will sputter almost to a stall and then come back. It seems like the problem fixes itself once the hydraulic system heats up from heavy use. if I stop and get out for a 5 or 10 minutes the hydraulic system seems to cool down and the problem comes back. I thought it could be fuel a fuel issue, but if it is parked and running at 2100 RPM its fine. It is only when the tracks are moving that this seems to happen. This machine has 500 hrs on it
Fishfiles
I would presume you have the deluxe instrumentation panel , put the panel to tools then vitals and monitor the hydraulic charge pressure from start up to warmed up , take note to what pressure it acts right and what pressure it don't , you may find that when cold the oil doesn't produce as much pressure as when hot , if so then change the hydraulic oil to a thinner weight
Change the fuel filter, they are to be changed every 250 hours. 98% of all running problems can be solved with a new filter.
