Can I assume that if I remove the bypass hose I use these two nipples for the heater hoses. ThanksMost skid steers have the hoses installed at the bypass hose connections.
That's how they normally install them, yes. Each engine is slightly different though, hopefully it will work all the same.Can I assume that if I remove the bypass hose I use these two nipples for the heater hoses. Thanks
