Phydeaux
- Sep 25, 2013
- 6
Hi all, new to forum. I have a 763C with 4400 hours. Occasionally when it has sat overnight or longer it acts like it's lost prime. Not always, only about 25% of the time. When I go to start, it will start to fire for about a half second, then I'll have to crank and crank, and it will eventually start. Once started, it will run fine, and if shut down will re-start fine if it hasn't sat for more than a few hours. I occasionally see a bit of fuel seepage from the top of the injection pump where the injector lines attach, but not a lot, and not often, and not necessarily when it has the starting problem. I understand there are some o-rings in there I need to change? I've seen no other fuel leakage. Thanks in advance for any insight!
