I've got a older 732 with the Ford engine. It has run fine since the last problems in '05. Now, it acts like it has run out of gas and the engine dies. It will restart immediately then die after a couple of seconds. If you wait a while it seems to come out of it somewhat yet, still die. When you get it running again sometimes when you advance throttle it dies. Yesterday, it ran fine for over an hour then this all started again, and, it was backfiring before it died. I advanced throttle 100% then it started and ran fine enough to finish the job and get it to the shed. This has been happening off and on for a couple of weeks. Before that it ran fine as long as you kept fuel in the tank. Any ideas? I have done no actual changes since '05 when I replaced plugs, etc. Thanks in advance Greg
