We have a 231 bobcat and the machine is dropping rpms just sitting still from a full rev, also if its at max rpm and you quickly pull it to idle it sometimes will stall out. It all started from when my dad ran some bad fuel through it. We replaced the supply lines, filter and the inline filter. I took off the lines and cleaned them, and pulled off the plunger caps and they are clean inside. also removed the tank and had it cleaned. so i'm wondering if the return fuel lines could be causing this issue or if the injection pump could be ruined? any tips? I also took off the banjo fitting going right into the pump and check for a filter or screen and didnt see anything.
