Need help with type of hydraulic oil to replace in gehl2600
Crf325
I just replaced or I should say I rebuilt both front bucket cylinder . What type of hydraulic oil should I use? I've read all kinds of different things online from hydraulic oil to motor oil to trani fluid. So what should I use
Grzes
Any of the above should work, especially on older machines. However, keep in mind that fluids for hydraulic systems are designed specifically for that purpose. They don't tend to foam up create bubbles), as oppose to engine oil, which may turn into a foam bath coming out of the hydr. fluid tank. I would contact a local dealer and see what is recommended for a particular model. Otherwise stick to some hydraulic fluid available at any automotive or heavy machinery parts supply.
