I have a 248b cat skid steer loader. I would like to be able to run the auxillary hydraulics while outside the cab. I have a grain auger that runs on a hydraulic motor and a concrete mixer that is driven by a hydraulic motor. I would like to turn on the hydraulics while outside the cab and be able to control the motors with a open center spool valve if this is possible. Any suggestions? Also, I recently purchased a high flow shredder built by the terminator people and I want to know how to turn on the high flow hydraulics. It looks like the high flow ports and the standard ports run off the same hydraulic lines. I was told that I might need a jumper in the electrical plug to get the high flow to work.
