Hi Guys , Have a couple of questions regarding the specs of my 226b (06), I am trying to understand the specs for this machine. Rated operating capacity is 1,500 lbs, or up to 1,600 lbs when including the optional counterweight. Is this the max weight it will lift off the ground because i am sure I have lifted more (2k lbs) off a trailer. Just trying to understand . also will this machine have enough hydraulic flow to run a hole auger ?? thanks Ragweed
