Gazza
- Nov 27, 2007
- 64
I just purchased a non-running N844LT engine out of a 2008 model L175 (thanks again Tazza) It appears this engine was replaced with a new crate engine in April 2010, it has been sitting in a dealers factory since then. I assume it has some serious problems otherwise they would not have gone to the trouble of replacing it, but at a quick look over we can't see the obvious reason for the transplant. We have not dismantled it yet, just carefully looking for the problem. The engine turns over 360degrees easily and has compression, the sump has been changed and none of the big end bearing caps are discoloured. The bottom of the engine has not been cleaned but the inside is spotless, even the pistons are still clean alloy, no carbon on them at all. The rocker cover has been removed, we assume to check for bent push rods or broken cam, all are working OK. Exhaust manifold is clean inside, so no sign of excessive oil use. The engine has net been cleaned externally and there is no sign of water leakage or head gasket problems. So before we get into it I thought I could ask if anyone has heard of any problems with this particular model or any thoughts to what the problem could be. thanks in advance, Gazza
