Bobcat  > General Repairs  > Re: How do you chain down a bobcat to a trailer?
 Author Thread: How do you chain down a bobcat to a trailer?
cchardwick is not online. Last active: 4/20/2007 11:18:06 AM cchardwick
www.aaawebmaster.com
Posted: 02/11/2007 06:02 PM
I just bought a car transport trailer, 16 feet x 6.5 feet, and want to chain down my bobcat on the trailer, can anyone give me some advice on what kind of chains to buy, what are the regulations, and where to attach the chains to the bobcat?
V-TWIN is not online. Last active: 3/31/2008 12:01:13 PM V-TWIN
Top 100 Poster
Posted: 02/12/2007 01:19 PM
I am sure there are several ways to secure your machine, the way that works the best for me is to run a chain through the loop rear center of machine (853) to the trailer. With the machine on the trailer backwards drive the machine forward tightening the chain. Lock the parking brake, then throw the chain over the front quick-tach with the chains hooked forward of the machine. Then chain jack the front of the machine chain till both chains are tight. basically pulling the machine in both direction. A good 3/8 chain or bigger will be fine, with a binder or chain jack. " I had a hitch break putting me, truck, trailer, and machine all in the ditch skid-steer held on fine"
sterlclan is not online. Last active: 1/19/2015 5:34:30 PM sterlclan
Posted: 02/13/2007 04:29 PM
Ive seen machines with a single chain on the rear slide on the deck...I use two on the back and one up front . Jeff
The difficult is no problem....................................................the impossible just takes a little longer. Try it........You might like it
Posted: 02/13/2007 05:29 PM
The minimum were are allowed here is 3. You can't just loop a chain through the tie down ring it has to be hooked on the machine, so the machine can't slide sideways on the chain. Also the fron chains must to hooked to the frame od the loader then pass up over the attachment to secure it down to the trailer. I generally use 4 shorter 5/16 grd 70 chains as opposed to 2 longer ones.
Hook the rear ones pull the loader forward until they are tight, then run 2 front chains over the bucket and down to the tie down on the front. Pull the front one tight with beartraps and bungee the handles shut
Chains in any direction must have a minimum working load limit  (WLL)  of  %50 of the load
I still need to put something on the backhoe bucket to tie the boom down
Posted: 02/13/2007 06:36 PM
I should take some pics of my skid steer, I have nothing in the rear to tie it to, the only way I can figure is to run chains around the rear door from top to bottom on each side. The front is the same way, I have nothing on the frame to tie to. The only thing I can see is to run around the lift arms but I'm going to have to watch that I don't put pressure on the lift cylinders. I bought some chain / hooks / binder and I'll try to hook it up tomorrow. Maybe I'll post a pic or two so ppl can give some advice. The guy at Home Depot said he worked with the state with bobcats and they require four chains, one on each corner.
WebbCo is not online. Last active: 9/12/2013 6:40:17 PM WebbCo
Top 50 Poster
Posted: 02/13/2007 08:03 PM
I would check with your local Highway patrol, they dish out the fines and set the rules.
All of my salespeople have had an issue with the law doing it just right, and when we think we got it all down correct... the HP changes the rules....
Hope your car hauler is up to the task...most are not.
Mark
Mark Webb 15 year ex Bobcat employee.
140mower is not online. Last active: 6/15/2013 6:09:04 PM 140mower
Posted: 02/13/2007 09:12 PM
 With-out seeing your machine and what it has for chain points, what I would do is wrap the chain around the axle tubes, hooking the chain to it's self then attach to the opposite side of the trailer. When finished both the front and rear chains should form an “X” across the deck of the trailer. Also, make sure you pull over after the first mile or so and re-tighten the chains, as rubber tired machines are notorious for bouncing loose, but after a re-tighten seem to hold put quite well. I always use four chains and four binders, and don't forget to bungey or wire the binders closed. Also, around here to be legal you should be using grade 70 transport chain and hooks.
 Something to consider with your trailer is that the weight really adds up fast. On my 14000lbs trailer almost 2500lbs is used just in the weight of the trailer it's self, add a skid and a couple attachments and suddenly there isn't much available gvw left over. Also what is your tow vehicle rated for? Being legal sure isn't cheap, no matter how you look at it.
 Hope some of this helps some or atleast makes a little sense.
 Don
If it wasn't done the hard way, I didn't do it.................................................................. 2006 Bobcat 430 with 36", 24" & 12" buckets & hoe-pac ....2011 s205 with tilt-tach, 66" tooth bucket, 66" smooth bucket,84" light material/s
jmatt20 is not online. Last active: 9/9/2014 4:11:20 PM jmatt20
Posted: 02/13/2007 10:45 PM
in CA. you must have four separate tie down chains or straps ,on my older machine i used the backhoe mounting balls in the front and in the back there where slots on the lower side of the machine also on the axle braces there were slots that a hook would fit. on my s220 i use four nylon straps with ratchets ,rated at 10000 lbs each ...15.00 bucks at home depot and D.O.T. approved . the 220 has two loops of steal on the front of the boom just above the bucket,and in the back i put the hooks in the hole you use to grease the back of the lift arms. if you tie the machine down without tieing over or to the lift arms you must also have a tie down for the lift arms so they can not come up during transport. the old way where you hooked to one side of the machine then thru the d ring on one side of the trailer across the deck thru the other d ring and then to the other side of the machine is not acceptable to the chp it give you a four point tie down, but not four separate chains or straps. i know ,83 dollar ticket.
Posted: 02/14/2007 04:41 AM
At least th Ca fines are not to bad, insecure in Ontarion is $390 Smallest commercial vehicle fine is 290
And they are neither nice or resonable about it
Posted: 02/14/2007 08:12 PM
OK, I made a web page with photos to show you guys what I have so far. Check it out and post comments / suggestions: http://www.capsandstems.com/ed/bobcat_tiedown.htm
Tazza is not online. Last active: 1/22/2015 7:37:48 PM Tazza
Posted: 02/15/2007 12:10 AM
It all looks good to me except the back door. I honestly wouldn't trust holding a 2 odd tonne machine down by holding on to the rear door like that. My 743 has tie down points near each axle tube and also has them on the side of the main chassis rite at the back corners.
nobull1 is not online. Last active: 4/28/2014 8:14:28 PM nobull1
www.bluebarn.ca
Top 50 Poster
Posted: 02/15/2007 05:10 AM
When you added the larger hooks did you make sure they were grade 70. The DOT guys will consider the strength of the chain by the weakest part. As was said previous I don't think I would use the door for securing the machine. The cost of having a couple of hooks/rings added wouldn't be very much, and then you would know it's secure.
"Choose a job you love, and you will never have to work a day in your life" 1997 763F
Posted: 02/15/2007 06:37 AM
Yea, I wish I had tie down points but unfortunatly with this older machine I don't and have to improvise. That back door is as solid as a tank, probably 1/2 inch steel and weighs a ton. I bet it's stronger than any hook out there, although not as pretty as some hooks would be. Although I'm sure the state trooper has the final say as to what is secure enough and proper. As for the extra hooks on the ends of the chains, they were not grade 70 but the chain and hooks that I bought that were grade 70 had a working load strength of 4700 pounds. I got the extra hooks non-grade 70 in a larger size because the larger ones had a working load of 4700 pounds and I wanted it all to match as far as load rating. What do you think about the nylon strap around the back of the bucket? Do I really need it and did I strap it right? I was thinking maybe I should have went over the bucket and down around the front, what is the purpose suppose to be, to secure the arms or secure the bucket? With the chains going around the lift arms and the hook on the frame I'm thinking I may not need the strap. I stopped by a bobcat and trailer that is used at our elementary school down the road and they got it all wrong LOL, I'm glad you guys are helping me out here. They used one chain on the front and just looped it through a hook in the middle so it looks like it can slide sideways. I'm glad I didn't use that for an example of how it's supposed to be done. Man I need some rear view mirrors on this skid steer because it's real scary driving up ramps in reverse when you can't see the ramps or the trailer! I bet that's why they moved the arms to a different position on the newer skid steers. I'm thinking of running out today and getting some mirrors that will attach to the ROPS and swing out to the side for loading and back in for driving.
www.bluebarn.ca
Top 50 Poster
Posted: 02/15/2007 10:41 AM
Quote: Man I need some rear view mirrors on this skid steer because it's real scary driving up ramps in reverse when you can't see the ramps or the trailer.
I have the same issue and have a thread going trying to find a good solution. It is just too cold out at present to fool with the mirrors and brackets, but I will be at it soon.
As far as the door goes I don't see it as a problem so long as the there isn't anyway for it to come unlatched. If that was to happen it might become a issue.
When I first started hauling my tractor and excavator I went to the people who give out the fines and said; “what do I need to do to keep you happy“. The first thing they said was nobody ever calls us to ask that. The fact that I did made it easy to get a little of his time. In our area you need at least 4 chains of grade 70, criscrossed and secured. If you have a bucket it is supposed to have a separate chain for the bucket to make sure the arm/bucket cannot move. Myself I use four for my excavator but the front ones cisscross over the bucket and between the teeth, so there is no way for the bucket to move. I would think that the bucket on the skidsteer would have to be secured in a similiar way. All of this you can  find out from your local authorities. I'm sure they can tell you what they consider important, and the proper way of doing things. In our area if you get in a accident with a piece of heavy equipment, they are all over you with inspectors and whatever. If they can find fault with what you did or the equipment your using, you are in big trouble.
Posted: 02/15/2007 04:51 PM
Speaking of mirrors, I've been working on the problem myself and found the best place to put a mirror, on the lift arms. I searched the web and found one photo, check this out: http://www.mirrorproject.com/show-image.mirror?id=19306
www.bluebarn.ca
Top 50 Poster
Posted: 02/15/2007 05:14 PM
That will work for mirrors for sure, but I would like to be able to have them tucked  under the arms if possible(convex). I know if they are stuck out I will hit them sooner or later. In the end your pic might be the best answer though. If the weather ever gets back to above freezing for a day or to I might be able to figure it out.
Posted: 02/15/2007 05:47 PM
I just got back from my local Case dealer and I was surprised that the only mirror they offered was a large rear view mirror, useless for backing up on a trailer but good for avioding buildings. Looks like there is a good market for bobcat mirrors if anyone is looking for a good product to produce and market! Seems like it would be easy to make one that clamps onto the arm with a pivot / swivel that will fold out for backing up on a trailer and fold down flat against the top of the arm for everyday use.
www.bluebarn.ca
Top 50 Poster
Posted: 02/15/2007 07:20 PM
Sounds good to me. Do some research and get it work, than post pictures so we all can benefit LOL. Seriously though I think your on the right track. I am just amazed that someone hasn't figured this out before.
pro70z28 is not online. Last active: 6/16/2008 2:00:57 PM pro70z28
Top 100 Poster
Posted: 03/12/2007 08:02 PM
I just registered on this site tonight. I'm glad I stumbled across this thread. I don't know if you can see in the pic of the front, but I tie everything down on my trailer with hitch pins. (don't know if you can see the red Pins?). I have a rack bolted to the trailer that holds all the attachments. I hold the Bobcat in place by running the forks iinto square tubing that is part of the attachment frame. Then pin it in place with 2 hitch pins through fabricated clevices that are part of the attachment frame. I have ratchet straps for the back, (I don't use them all the time, but will from now on). The mini track loader is about 2,500 lbs. After reading this thread I'm thinking maybe I should replace the straps for chains? Don't need any fines. [URL=http://www.glowfoto.com/viewimage.php?img=12-204205L&y=2007&m=03&t=jpg&rand=7239&srv=img3][IMG]http://img3.glowfoto.com/images/2007/03/12-2042057239T.jpg[/IMG][/URL][URL=http://www.glowfoto.com/viewimage.php?img=12-204206L&y=2007&m=03&t=jpg&rand=2079&srv=img3][IMG]http://img3.glowfoto.com/images/2007/03/12-2042062079T.jpg[/IMG][/URL]
Top 100 Poster
Posted: 03/12/2007 08:07 PM
Can photo host site BB codes or HTML codes be used on this site? free image hosting free image hosting
Top 100 Poster
Looks Like BB Codes work.
Top 100 Poster
Posted: 03/12/2007 08:13 PM
Is there a way to edit posts? The link in my first post is making the screen wide. Is there a way I can remove it? Sorry.
Posted: 03/14/2007 02:58 PM
Like this
Note hooks on loader, chain not simply passed through the rings,
On the front the chains go over the attachment holding it down.
Load binders on both rear (loader) chains  and pull the ones on the oposite ends tight.
Tie load binder handle shut.
Cam2 is not online. Last active: 12/29/2008 6:33:36 PM Cam2
Posted: 03/15/2007 06:57 PM
Skidsteer, What size trailer is your Bobcat on? I noticed how far forward you have your unit on the trailer.
Posted: 03/15/2007 07:35 PM
Its a 19' tridem, but if I was doing it again, I'd set it up with a little more tongue weight, its Center of axel group is about 15% rear of center. If I did it again I'd have at least 25% more deck forward of the center of the axel group. Learn as you go, I guess.
15% works good on a tandem in my opinion,  because the axels can equalize alot more, but a tridem is pretty limited. The hitch on the truck must be the right hight too, or one set of axels is not carrying there share of the load
 I have to careful to load a little extra tongue weight because if you crest the top of a sharp hill where the front 2 axels are carrying most of the load it will lift up on the tongue.
Center of gravity of the loader is near the rear axel and I try to keep that forward of the middle axel on the trailer.
The 19' is nice as it give me plenty of room to load attachments  over the sides in front of the trailer fenders, and still put the loader with a backhoe on behind.
Posted: 03/15/2007 07:42 PM
I gotcha!!! I thought it may have been a triple axle, but wasn't sure. Do you feel the need to have 3 axles with that load and does that rig bring alot of attention with the State police in your area? I bought a 12,000# pd and derated it to 9998 to keep under DOT because I do not have a CDL. I hate trailering my unit, and often think of just paying someone to deliver it to the job site. Average prices around here is about 2.50 -3.00 per loaded mile.
Posted: 03/16/2007 06:48 AM
Here your commercial if your doing anthing that looks like work, weather it pays or not. And if you truck weighs over 10 000 or your trailer is over 6600 then you are considered a 18 wheeler. Daily circle check  records and hours of service must be produced on demand.
The catch 22 is if you licence either the truck or trailer over that weight, then even when you don't weight that much you still have to do the paper work and comply with hours. When were working in the summer and I have my licence up over 10k, I don't drive that truck more then I have to. I bought a  1/2 to run  into town with.
The one idiot we had here stopped me on evening, put me on the portable scales, and I was 10440, so he fined me $390.00 for not doing the paper work my walk around inspection, (which I would not have needed if I was 441 lbs lighter) even though the truck had no mechanical defects, it had 11000 miles on it.
So don't kid yourself, they are all on a “quota” system and flat deck pickups and larger trailer are  a**hole magnets just like a semi truck.
Here I wish they would put one of those truck police in every commercial vehicle, then when the whole economy colapsed within a week because no one can comply with all the BS rules, they could begin to rethink some of them.
In Ontario you can drive you 300 hp diesel 35' motor home and tow a big a** boat for 30 hours straight to come here fishing, but not you 3500 pickup to the coffee shop.
Posted: 03/16/2007 06:54 AM
Oh and no  for that load a tandem is more then adequate, there is @ 7500 machine and grapple.
We haul our 350 JD crawler on there and its 10500, thats why its a tridem. Though its good for the skidsteer if I need say the loader, hoe, brusher, grapple and a bucket I can haul it all at once with that truck and trailer.
pelpel is not online. Last active: 7/19/2008 10:36:30 AM pelpel
Top 100 Poster
Posted: 03/22/2007 02:54 PM
Small trick, instead of bungee cords or wire to secure the handle of the binders, I got myself a few shackles, the bolt fits into the chain link, the loop over the handle a few inches from the end, no more wires or cords to mess with..........
Goto to page:  Prev Next
Forums  > Bobcat  > General Repairs  > Re: How do you chain down a bobcat to a trailer?
