daewoo 601 trying to make it roll without power so it can be worked on
Mayer075
Trying to swap motors from one machine to another. Is there a release anywhere on the machine to make it freewheel so it can be pushed once the motor is out?
If it is hydrostatic drive then no, it will not just roll. If you disable the park brake and remove the hydro lines to the motors you can roll it slowly. Carefull not to get trash in the drive motors though.
Mostly when i do things like that, i use brute force to drag it out.
