ok finally getting around to installing this mower to see if it works.I have to install a case drain as the mower has 3 lines to it. has anyone ever done this? can I go back to the filter and tap in there instead of at the case itself? isnt one of the filters on the return side? could I just T a line ?Fecon on Cats and Takeuchi but always on machine 8 tons or more , you talking 3 ton mulcher head or a three ton machine , 3 ton machine would be like an over sized weed eater
If your machine doesn't have a case drain line at the couplers, i can't see why you can't tap in. Ideally a line that goes directally to the reserve tank.ok finally getting around to installing this mower to see if it works.I have to install a case drain as the mower has 3 lines to it. has anyone ever done this? can I go back to the filter and tap in there instead of at the case itself? isnt one of the filters on the return side? could I just T a line ?
ok ,I talked to the guy (skid steer solutions) that sells the terra mowers on ebay and he said they just finished testing and they no longer require the return for bobcats.I dont know what to do now. I got hoses and hooked it up and it runs fine and when you stop(let of switch) just a dribble comes out the third hose. I would think maybe more would come out if it was stopped while switch was engaged ? I got a quick exchange mount from bobcat to weld on it and it should be ready to try out.If your machine doesn't have a case drain line at the couplers, i can't see why you can't tap in. Ideally a line that goes directally to the reserve tank.
The case drain lines shouldn't have much flow, you will get more when the motor is under load though.ok ,I talked to the guy (skid steer solutions) that sells the terra mowers on ebay and he said they just finished testing and they no longer require the return for bobcats.I dont know what to do now. I got hoses and hooked it up and it runs fine and when you stop(let of switch) just a dribble comes out the third hose. I would think maybe more would come out if it was stopped while switch was engaged ? I got a quick exchange mount from bobcat to weld on it and it should be ready to try out.
