Tree shear with buncher arms Posted: 08/08/2012 06:28 PM |
| Can anyone tell me what brand this tree shear is?
http://sanantonio.craigslist.org/grd/3138769630.html
It looks like the skid steer mount was added later.
Any negative comments about this shear? I am considering buying it for use on my New Holland L190.
Thanks
Jeff |
KarlB
| Total Posts: 53 |
Re: Tree shear with buncher arms Posted: 08/08/2012 06:45 PM |
| Ransome
http://www.ransome-equip.com/ftshear.html
mahans7
| Total Posts: 317 |
Re: Tree shear with buncher arms Posted: 10/31/2012 04:42 PM |
Specifications
Model Weight Height Width at Shear Arms Overall Depth Price
Tree Shear 1,810 lbs 57" 63" 40" $ 16,900
Tree Shear w/ Accumulator 1,950 lbs 57" 63" 40" $ 17,900
Additional Specifications
Cylinders Number Rod Bore Stroke
Shear: 2 2 1/2" 5" 10
Double Grapple: 1 1 1/4" 2 1/2" 12
Accumulator: 1 1 1/8" 2" 8
Features:
· Ideal tool for thinning in small logging operations.
· Ground level cutting, eliminating stump problems.
· Double arm grapples securely grab the tree as the shear arms are activated.
· Designed for machines with a minimum of 40 hp, 13 gpm, 1700 psi, and 1,700 lbs of operating capacity.
· Cylinder is rated at 3000 psi and optimum results will be obtained near those levels.
· Shear blades are comprised of 1" high tensile steel with milled knife edges and are easily replaced when worn.
· The optional accumulator enables the shear to "bunch" cut trees when operating in smaller wood, thereby improving productivity.
· Machine must be equipped with auxiliary hydraulics; grapple arms operate from the same auxiliary hydraulic circuits that control the shear blades.
Too big for my 743. |
Bobcat 743 with 909 Backhoe. M7 |
mahans7
| Total Posts: 317 |
Re: Tree shear with buncher arms Posted: 10/31/2012 04:50 PM |
I need to brush up on my image posting skills, here's another try:
mahans7
| Total Posts: 317 |
Re: Tree shear with buncher arms Posted: 10/31/2012 05:15 PM |
brogan007
| Total Posts: 12 |
Re: Tree shear with buncher arms Posted: 01/01/2013 05:38 PM |
| Looks like an awesome tol to have. Hwever, I'll bet there's not much change outta $10k. |
mahans7
| Total Posts: 317 |
Re: Tree shear with buncher arms Posted: 01/01/2013 10:52 PM |
| Cost new is $16.9-17.9K. 10K probably only works for WELL used. |
