Bobcat  > Skid Steers  > 443 Concrete Breaker
 Author Thread: 443 Concrete Breaker
dlschaan is not online. Last active: 10/30/2004 4:26:50 PM dlschaan
Top 100 Poster
Posted: 10/14/2004 04:14 PM
I purchased a Stanley Breaker BR85 on ebay for my 443B. Fabricated a mount, bought hoses and mounted it. It worked 5 min then died. Had it tuned, worked 5 more minutes and died. Took it back and the repair guy removed the pressure adjuster, replaced it and it worked again - for 5 minutes. When it worked, it worked well at partial throttle. Is there something about the 443 that is causing the failure or should I be looking for a newer hammer. So far I've only about $600 invested and to get a BOBCAT model I'd spend several $1000. Any hints - places to look, things to check?
Tigerotor77W is not online. Last active: 7/22/2007 2:48:37 PM Tigerotor77W
Top 50 Poster
Re: 443 Concrete Breaker
Posted: 10/18/2004 03:30 PM
(Try PMing Stu...)
Opinions expressed in this message are those of the author and do not necessarily represent the views or opinions of Caterpillar, Inc. or Bobcat Company, both of which are copyrighted trademarks of their respective companies.
StuZ is not online. Last active: 12/29/2005 4:14:49 PM StuZ
Top 100 Poster
Posted: 10/19/2004 06:27 PM
I'm not sure I understand the problem ?? Is it the breaker that he is rebuilding or the skid loader ?? Does he have another Bobcat to mount it on and try it ?? Has he flowrated the hyd. system ?? Does the breaker have nitrogen in it ??
Top 100 Poster
Posted: 10/26/2004 10:48 PM
The Bobcat hydrualics have not been flow tested however they drive a trencher that digs deep if not fast. I ran the trencher for 10 minutes with no slowdown. I tried the breaker again. The breaker just came from the repair guy (who is not a breaker service tech) (non in town), and he had it working for several minutes with only about 500 psi. I took it home, hooked it up and after 5 min of good work, it started to slow in in 15 seconds, no more hammering. Based on working with the trencher, the Bobcat flow and pressure seem satisfactory even if not a lot. But it boggles my mind that if the hammer works at partial throttle, why does it all of a sudden want to quit? Or is a hammer sensitive to flow and pressure and while it works for awhile, will it then overload it internally? BTW, based on it working at the hyd shop, there must be nitrogen in it and he did recharge on an earlier visit. Thanks for any ideas.
Eric is not online. Last active: 1/6/2015 4:27:58 PM Eric
www.bikepics.com
Top 50 Poster
Posted: 01/23/2005 01:01 PM
Maybe heat is affecting something inside. Warms up in 5 minutes, something is responding to the heat, and making it stop. I know this is why they use nitrogen to charge. This gas does not expand when introduced to heat. Just an idea. I dont know very much about the inerds of breakers but I do run them very often. Good luck.
97 FL 10 Wheel Dump Truck, 2005 Zieman 2660 Trailer, 963 Bobcat, 78" Smooth Bucket (1.3 cu/yd cap.) and Tooth Bucket, UB Breaker(1,100 ft-lb), Pallete Forks, 763 Bobcat with Rear Stabalizers, 62" Tooth Bucket, 68" Smooth Bucket, Hammeroc Breaker (750 ft)
Page 1 of 1
Forums  > Bobcat  > Skid Steers  > 443 Concrete Breaker
