My 2060 quit working today. The engine starts and runs fine but controls stopped working. No tilt or lift with foot pedals. No forward or reverse with t-bar. Just before it quit working the steering acted up, not moving like it should to one side. When I turned the t-bar there was a ratcheting noise. shortly after that the tilt/lift and the drive both quit. When I shut it off and restarted it the tilt worked just a little then quit again. One of the hydrostats has been leaking for quite a while but has been working fine. I keep putting off fixing it because of so many other things needing repair around the farm. Just make sure the oil level is ok. Also one tilt cylinder leaks a little. I'm wondering if there is a lockout or switch not working properly. Hoping not the pump or something else expensive. Thanks for any ideas. Pete.
