timmyd1970
- Apr 12, 2012
- 4
i recently aquired an older m-371, and have found multiple hydrulic issues with it. upon initial inspection found the o-rings leaking between the valve bodies. i topped off the fluid, and this only increased the fluid loss. i resealed the valve bodies, degreased, topped off the fluid level again, only to find that the pressure line to the valve assembly is leaking as well, and may have been causing most of the leakage in the first place. after speaking with the bobcat dealer, and techs, took the valve assembly in to them only to find that someone has welded the pressure control valve solid. this, i am guessing may be causing most of the problems. my problems are that i can't find parts for this unit. i need help finding the hydrulic valve assembly, and/or the pressure control valve. i have been calling, and searching online for the past couple weeks, but with no luck so far.
