Starting Issues
NeedingHelp1580
Just recently we started having starting problems. You go to turn it over and the ignition will not turn over. Its like its not getting no connection. You try to start it and it does not do anything but the thing about it is, it will have that problem for a few minutes and then all of a sudden it will start and seems to run fine. It is 50 degrees outside and its not only happening in the morning. Please help.
leaddog
Sounds like starter sol. My excavator did that and I had to replace the sol. Just out of the warrenty and guess what it's starting to do it again. You can check and see if you are getting power at the sol. and if it clicksin and sends power to the starter. You might also have Two sol.s if it is 24v. My excavator does. they do this so they can run small wires for control. I put in a different sw and ran heavyer wires as my sw was sticking and that was what made the sol and starter burn out first. leaddog
