My 853 sits in the shop and is used very little. Most times I have to squeeze the bulb and prime it after it has set for a few days. (the S185 has heat & ac should I say more)
I just picked up a Mr Gasket eletric fuel pump for deisel. Looks like it would be pretty easy to hook the hot wire to the fuel cut off on the injection pump. It's only hot with the key on. Pump use's a 5 amp fuse. Anyone what's the amps on that wire?
thanks dennis
thanks dennis
