Sauer Danfoss 4445096 Hydraulic Drive Pump - control input seal - T200 Posted: 11/19/2011 08:15 AM |
| Hey guys, I have a T200 with the the pump mentioned in the title(I think). The seals are leaking where the forward/reverse control shaft goes into the pump. I was wondering if anyone knows if they are "special seals" I would have to get from the dealer or can I get them at NAPA?
Thanks in advance |
T200 |
Re: Sauer Danfoss 4445096 Hydraulic Drive Pump - control input seal - T200 Posted: 11/19/2011 01:24 PM |
| If you are talking about the pinon shaft seals they a pretty cheap at your dealer. you will want the o-rings that go there also. sense you will have the steering apart do both sides. Depending on how many hours your will probably need some steering parts also, especially on a track machine |
Re: Sauer Danfoss 4445096 Hydraulic Drive Pump - control input seal - T200 Posted: 11/26/2011 03:14 PM |
| I got the seals for both pumps from Bobcat. I tried sourcing the seals from my local Napa but had no luck. There are 2 seals for each pump and they cost a total of $44 for all 4 seals from bobcat.
T200 |
