Does anyone know how to replace the drive belts without removing the engine? There is a hole in the firewall behind the seat, and the diameter of the hole seems to be the same diameter as the smallest sheave on the clutch-drive pulley assembly. I thought I could loosen the clutch and slide it forward through the hole far enough to remove it so I could slip the belts on. On further examination, that doesn't seem like it would work.
