Bobcat  > Skid Steers  > Bobcat 763 Chain Case Drain Plug?
 Author Thread: Bobcat 763 Chain Case Drain Plug?
HarryN is not online. Last active: 1/15/2015 9:52:41 AM HarryN
Posted: 09/09/2011 09:51 AM
Recently I purchased a Bobcat 763. Getting around to changing all the fluids and have come to draining the 9 gallons of oil in the chain case. The manual describes removing the "Drain Plug" and "washer". So I assumed you unscrewed the bolt and accompanying washer (like the drain plug on a car's oil pan) Not so.... This has a rubber grommet plugged into the drain hole!! (basically a rubber cork) For some reason this just didn't seem right, so I went to the local Bobcat dealer to buy another "Plug". That way I knew it would be the right item. To my surprise it is a "rubber grommet" with what looks like a nail you push into the center of it, which I assume expands the grommet to seal the hole and so it doesn't fall out. (there is no "washer" as described in the service manual??) My question is, Do you need a special tool to remove the rubber drain plug? Or, do you just rip it out of there? Being I don't have a lift... and barely no clearance as I get under the Bobcat, I guess you better be ready with a container for the have 9 gallons of oil that will be draining out!! Personally, I this this drain plug so is a poor design. But what do I know - LOL
Covington, Louisiana USA 1999 Bobcat 763F
bobbie-g is not online. Last active: 5/3/2013 7:51:31 PM bobbie-g
Re: Bobcat 763 Chain Case Drain Plug?
Posted: 09/09/2011 01:30 PM
Harry. I agree, poor design, but it seems to work OK. No pressure to speak of on the plug. I put blocks under the back wheels to tip the machine forward, then open the fill plug at the front of the chain case (right in the middle, just behind the lift cylinder, maybe it takes a 1/2" drive ratchet extension to remove it??? I forget. Anyhow, get all you can that way, then go back to the plug-in-the-rubber-grommet. Just pull the plug out with pliers. Has a slight ridge on the backside of the plug, so you'll have to work at it to get it out. Then realize you should have had a large pan under there with you...... Glad you got a replacement grommet. I always like to have one on hand in case I mess up the existing one. Three other points: First, the grommet in metal is the chain case drain; beside it is the grommet into plastic which is the fuel tank drain. Second, the Big Boys tell me I really should take off the chain case cover and mop out the accumulated metal flakes and junk in the bottom of the chain case. I'm contemplating doing that on the next chain case oil change. Third, since that oil only lubes the chains/sprockets, the best of forum advice (from Tazza, I think, but then he's an Aussie...) is to drain the chain case before you change the hydraulic oil. Then just drain the used hydraulic oil into the chain case and save a few bucks. For us casual users, I question whether the chain case oil even needs to be changed, but I'm a maintenance freak so I do it just because. Smiley ---Bobbie G.
RC in Trinidad, CO - 1995 751C (Peugeot engine), 1999 863G, Thomas 4-in-1 bucket, Versatec brush grapple, antique backhoe attachment, 4-way snow blade, home-built stump grubber, forks, Dymax tree shear, Ammbusher mower
Kermode is not online. Last active: 9/30/2012 7:02:24 AM Kermode
Posted: 09/09/2011 06:41 PM
I was just like you when I first encountered this. This has to be the stupidest design any manufacturer has ever come up with. Oddly enough, it seems to work. I have never managed to reuse the rubber grommet successfully though. They always seem to leak a little on me.
biggie is not online. Last active: 12/31/2014 7:31:55 PM biggie
Top 100 Poster
Posted: 09/09/2011 07:03 PM
Changed mine a couple of times.I lift the back of machine up, and remove the cover at the front of the chaincase, and pump it out with hand pump. I get a good view of what might be happening in there.
Posted: 09/10/2011 08:02 PM
After getting the drain "Cork", (still think that's a crazy design) I changed course and decided on Biggie's method. Plus I really wanted to see the inside. I removed the front chain case cover with eight screws (and removing the parking brake first) Used a rotary hand pump and easily sucked out most of the 9 gallons of old oil. Flushed it all out with diesel fuel (as recommended by local Bobcat dealer) using a pump sprayer. After that I just swabbed out the bottom of the chain case with rags. Made it nice and clean! Poured in 9 gallons of Rotella 15w40 and closed it all back up. Because this was the first time getting into the chain case, I think this was the best solution for me. The next time I can use the drain plug method as I'll be the only user of the machine. I took some pictures of it but don't see an option where I can attach them??
Tazza is not online. Last active: 1/22/2015 7:37:48 PM Tazza
Posted: 09/11/2011 03:03 PM
You did the right thing. You need to mop it out to get all the particles created when the chains and sprockets wear. I use diesel or kerosene on mine, works a treat.
For pictures, you need to host them somewhere like photobucket and copy/paste them into your forum post. If it messes up and you have the links, we will fix it up.
Posted: 09/12/2011 05:57 AM
Tazza. Here is one picture of the rotary hand pump in the bobcat to drain out the chain case oil. Checking to see if my first post of a picture worked?? Thanks for the tip.... http://i128.photobucket.com/albums/p187/HarryHarley/Bobcat%20763/th_BobcatChaincaseOilChange9-10-11003.jpg
Posted: 09/12/2011 08:47 AM
Tazza. I put the pictures on Photo Bucket as you mentioned, then did a right click to "copy image". Then "pasted" in the body of the post. And, that's how I got the small picture in the post. Is that the right technique? Is there something I can do to make the picture bigger? Thanks....
Posted: 09/12/2011 03:15 PM
To get the bigger image you will need to load the full sized pictue not just the thumb nail and right click/copy it. Everything else you did is correct.
Posted: 09/12/2011 04:10 PM
Ok Tazza, lets see if this works better.... more pictures that are full sized???  http://i128.photobucket.com/albums/p187/HarryHarley/Bobcat%20763/BobcatChaincaseOilChange9-10-11002.jpg
http://i128.photobucket.com/albums/p187/HarryHarley/Bobcat%20763/BobcatChaincaseOilChange9-10-11001.jpg
http://i128.photobucket.com/albums/p187/HarryHarley/Bobcat%20763/BobcatDrainPlug.jpg
OldMachinist is not online. Last active: 1/25/2015 5:38:50 PM OldMachinist
Posted: 09/12/2011 04:38 PM
Sorry I forgot to mention I fixed your image in the other post.
It looks like your right clicking and hitting copy shortcut not just copy.
Bobcat 453F ,Loegering steel tracks, Grouser steel tracks, 48" Dirt bucket, 48" toothed bucket, grapple bucket, 72" hydraulic vee snow plow and utility forks, 1954 Ford 860, 1952 Allis Chalmers CA, 1947 Case SC, Nashville IL USA
Posted: 09/12/2011 05:36 PM
So... that didn't work I presume. I'm using the free version of Photo Bucket, not the pro version. I'm uploading the orig images... does Photo Bucket re-size them to thumbnails? When I go there to right click on the picture, my choices are View image, Copy image or Copy image location. I tried both Copy image and Copy image location in the above posts and as you stated neither gave me a full sized picture in the body of the post... it that some thing I can correct or a setting I need to change? Thanks
Posted: 09/12/2011 05:49 PM
Oh, by the way, I'm using Firefox not IE. Would that make a difference?
Posted: 09/12/2011 05:55 PM
I fixed them for you.
Firefox doesn't play nice with the forum software, not sure why though. I just use IE for the forum, everything else i use FF.
The oil was in a bad state indeed, that is not a nice colour at all.
Posted: 09/12/2011 06:05 PM
You are very observant! You are correct... the oil was in a bad state. The middle chain cover was missing 6 of the 8 bolts, so I assume some water got in there. Being that I just bought it and not knowing or believing what the previous owner said or did.... is the reason I've been changing ALL the fluids. And glad I did!
Posted: 09/12/2011 08:11 PM
On a new to you machine, its always a good idea to change all fluids and filters. You then know exaclty what has been done and when it was done.
Ironwood is not online. Last active: 6/1/2012 7:27:40 PM Ironwood
Posted: 01/22/2012 04:18 PM
This is an old post, but just to add, I simply put the front tires onto cinder blocks (solid ones) and lifted the back of the machine with my forklift (Bobcat chained to the mast) and lifted until the chaincase oil all draind out the front plug hole. I hoisted it pretty high, but it was EASY compared to the rubber gromet hole underneath. The little bit left I used a small oil suction mechanism to suck it out, them flush with diesel I shot in there with the same unit. I took the front access cover off to do the flush and final cleanout (obviously) then dumped the 9 gallons of fresh oil back in, Ironwood
Page 1 of 1
Forums  > Bobcat  > Skid Steers  > Bobcat 763 Chain Case Drain Plug?
