28checkmate
- May 27, 2011
- 4
I recently started to recieve a code on my display that reads: FO A The code has not went away and my foot controls are locked out. I have no other visible lights on while engine is running and i am seated in seat with seat belt on! After the unit sat for a day the bucket lowered on its own and when i started it up the controls were working however they locked again after about 10-15 minutes of use! I have checked the wiring to the solenoids and they appear to be fine. I was told by the dealer to check the resistance through the solenoids to make sure they are not bad. He also said i could borrow their ecu to replace mine with to see if that was the problem. Has anyone had this problem and came up with the faulty part or problem. There are several other posts on here for this problem but i have not seen an exact answer to the problem. any help would be greatly appreciated.
