jay42782
| Total Posts: 14 |
mustang 345 repower questions Posted: 06/23/2011 07:39 PM |
| hey guys,
just picked up a mustang 345 minus motor.i have located a 4cyl diesel engine out of a small nissan pickup.i have heard it run and sounds good.motor has 120,000 miles on it.can someone tell me if this engine will work,fit..etc.i know il have to fab new motor mounts,shaft.throttle and plumbing just to name a few things.
the original motor was a 40hp gasser.this diesel is rated at 75hp.im suppose to pick up the motor this weekend and wanted to double check with you guys to see what your thoughts were.thanks for your time
| Total Posts: 10204 |
Re: mustang 345 repower questions Posted: 06/23/2011 08:08 PM |
You may have a problem because it does not have a govenor on it. Stationary engines have govoners so it gives the engine more power when its under load and lets it off when its not.
You really should look for a stationary engine for this job, you may be disappointed with the end results if you don't. |
jay42782
| Total Posts: 14 |
Re: mustang 345 repower questions Posted: 06/24/2011 08:50 PM |
| thanks tazza.any idea what would be a good engine for this project? whats a decent stationary engine to come by these days.also could you explain how to tell if a motor is governed or not.sorry for the dumb questions but i dont want to make a dumb move and buy something that wont be suitable for the skidder.as always thanks for your time! |
| Total Posts: 815 |
Re: mustang 345 repower questions Posted: 06/25/2011 08:06 AM |
Don't let the governor thing slow you down. Look for a belt driven governor off of an old gas-engined combine.
While an industrial engine may be an easier route, you are going spend potentially $1000's for a good industrial engine versus a few $100 for a good automotive engine.
Based on the information that you have given, I am assuming the engine that you are looking at is a Nissan TD23 (75hp @4300 RPM). You likely won't be able to use all of this power, as the RPM is probably too high for your skid steer. The good news is that this engine produces a peak torque of 111ft.lb @ 2200 RPM (equates to 46 hp), which is quite usable and makes this a bit of a power increase over your old mill.
Can you get the whole truck? There are likely a lot of parts that you will be able to use off of the vehicle to make your transplant simpler and more cost effective, i.e. motor mounts, cooling system parts, wiring, plumbing, accessory drives, etc.
So long as this motor will fit in your engine bay, I say go for it.
Good luck!!
SR |
1992 Bobcat 440B - 20 hp Repower, wide tires, aux. hyd., auger, rototiller, buckets - 42" & 50" mat'l, tine, grapple; 1996 Bobcat 773 BOSS (Pop's machine), material bucket, tine grapple, wood splitter, bale spear, forks |
Re: mustang 345 repower questions Posted: 06/26/2011 03:14 PM |
Skidroe makes a good point. A good replacement would be a Kubota, but they are over the $1,000 mark. If you were able to find a govenor, that would be perfect.
As for telling what ones have an internal govenor, that's a good question... Any automotive engine won't have one, as you are always changing the throttle due to driving conditions, industrial ones you just set and work away. |
jay42782
| Total Posts: 14 |
Re: mustang 345 repower questions Posted: 06/26/2011 08:01 PM |
| hey guys!
sorry i havnt been on.were trying to get our house ready to go on the market.well here is my dilemma...the motor i was looking at out of the pickup is just motor,transmission,alternator,starter,electronic fuel shutoff...etc.he scrapped the rest of the truck due to body damage.he was asking 1000.00 for the setup but will take 800.00.you guys think its worth it.if someone had to ball park completion what would you guess?i will be doing most of the fabrication myself.the rest of the machine is in good shape and hydraulics are suppose to be good as well.the machine has 1600 hours on it.i can not seem to find any good deals on diesel engines at the moment.anyways tell me what you guys think.thanks!! |
| Total Posts: 815 |
Re: mustang 345 repower questions Posted: 06/27/2011 09:43 AM |
Hi Jay,
When taking on a repower, a little planning goes a long, long way. I like to take a sytems level approach to the task, which means you look at every major system that interfaces with the engine, then work out a game plan of how to tackle each one; as well as how the modifications will impacts the over all machine. Normally, you won't have real good answers to some of the more minor things (i.e. thottle linkage, etc.) until you get into it, but as long as you knock off the more major ones, you should be in good shape. The internet is a great resource for gathering ideas, and parts to accomplish this.
Here is a list of things that I would want to figure out before picking up the wrenches (I think that we have already established that power will not be a problem, and we have spoke about the governor):
1. Space claim - will the engine (including the cooling system) fit? 2. Engine configuration - Is the general layout of the engine compatible with the layout of the engine compartment? i.e. comlpexity of intake / exhaust plumbing, accessory drive layout, etc. 3. Motor mounting - Is there structure in the engine bay where you need it? Can the engine be mounted without the transmission providing some level of support? Also, how is the starter mounted? Can you do away with the bellhousing? 4. Battery - Going from a gas engine to a diesel, you may need to mount a larger battery. 5. Starting Aid Actuation - you will need to set something up to operate the glow plugs. (the TD23 being an indirect injection diesel, it will likely have them). 6. Charging System Capacity - probably not a big deal, but worth mentioning 7. Direction of engine rotation - once again, likely not a big deal, but I know of a few cases where this was overlooked with disasterous results. 8. Drive connection - A big one, make sure you have this one well thought out before you start. 9. Budget - likely the most important factor. Most of the above can be solved by adding money, but if you don't have it... The biggest cost saver will be the ability to make/modify your own parts, or have friends that can (especially if they owe you money or favours!!)
There are more that I could add, but I think you get the drift of where I am going.
One other thing that is a good confidence builder is to find out whether someone else has performed the transplant (or one similar) to the one that you are about to undertake. Once again, the internet is a wonderful tool. In my case, I actually found a company that had developed a kit to put a 24 hp Honda into a gas powered 4XX-series Bobcat, so I knew that it was possible before I started. I looked at a few pictures of what they did, then went for it. I substituted a 20hp Chinese copy of a Honda for the engine (less than half the price of a Honda, and 1/4 of the price of another 16.5 hp Kohler, which was what was in it from the factory). The end result was a transplant that almost looks factory, and works way better than it did when it was new.
Besides all that, anyone can put the original engine back in... ;-)
SR |
Re: mustang 345 repower questions Posted: 07/14/2011 04:08 PM |
| hi, i put a toyota engine in a bob cat, it will make you think. luckily on mine the bobcat flywheel bolted to the toyota crank, all i had to do was open the center hole to fit the crank. after that the proplems were attacked one at atime. mine has a hand throttle so i put a throttle stop at the max rpm of the hydro. if you need help thinking write me for my number. russ |
Re: mustang 345 repower questions Posted: 07/19/2011 12:18 PM |
Would you have some pictures of the install and the finished result? We would love to see them and have you write up a engine swap story on the site.
Ken |
jay42782
| Total Posts: 14 |
Re: mustang 345 repower questions Posted: 08/25/2011 06:48 PM |
| its gonna be alive...i hope..lol
hey guys,been awhileive been busy working on the house.i finally went and picked up the engine.its a sd22 nissan.2.2L.its at my buddys house getting ready for install as i speak.i will post pics and progress as it goes on.one question i had was wich way does the hydrostat need to rotate and if it matters and why.i will keep you guys updated!! thank you!!! |
jay42782
| Total Posts: 14 |
Re: mustang 345 repower questions Posted: 08/25/2011 07:19 PM |
| everything fits and looks better connecting the flywheel to the hydrostat but not sure if rotation will be correct or not |
Re: mustang 345 repower questions Posted: 08/25/2011 08:21 PM |
| Rotation should be ok. Only exotic engines seem to rotate backwards *fingers crossed* |
jay42782
| Total Posts: 14 |
Re: mustang 345 repower questions Posted: 08/27/2011 09:28 AM |
| thanks Tazza!! i was hoping you would say that.we were thinking it would work fine also and everything just fits nice and puts the belt at ease to access.im really exited about this repower and think everything will go the way it should.my buddy thats doing it is very precise on the things he does.if its not right he wont do it.thanks Tazza and those who are helping me along the way.i will post progress as it goes on.thanks again |
