First remove the bucket and raise the boom and insert the boom locks. You will need to drain some oil from the chaincase. There are drain plugs at both the front and back. You will need a 3/4 drive breaker bar to remove them. Jack up and block the front of the loader so you can remove the wheel. Inside the operators compartment down by the pedals are access plates on the side of the chaincase. There are four 5/16 bolts holding the plates to the chain case. Remove these bolts and remove the plates. You do not need to drain all the oil from the chain case, just enough so it does not leak out when you remove these plates. After the plate is remove you will see the nut that holds the gear to the axle. Before removing this nut get some 5/16 all thread and cut 3 pieces to about 5" in length and 1 piece about 3" in length. You can either weld a nut to one end of the all thread or use a double nut locked together. Taper the other end of the all thread slightly and be sure the threads are clean and easily screw into the chain case where you removed the four bolts that held the plate. Screw the all thread into the chain case until it contacts the gear. Then tighten the all thread so the gear stays in position when you remove the axle. Once the gear is locked in place remove the cotter pin and remove the nut and washer. Depending on the age of the machine you may have a notched cover over the nut instead of a notched nut that the cotter pin goes through. Once the nut and washer are removed the axle can be removed. You will probably need to tap on the axle flange to remove the axle from the gear and inner bearing. Now you can remove the outer dirt seal and inner oil seal. If the sealing surface on the axle is worn you will need to install a sleeve so the seal will seal when you are done. On later machines a sleeve was installed from the factory. If yours is worn you will need to determine which sleeve you need. Now for installing the seals. The oil seal goes in first, this is usually slightly wider than the outer dirt seal. The lip of the seal goes to the chain case to hold the oil in. It need to be inserted about 1/4" into the axle housing so there is room for the outer dirt seal to be installed into the housing. The only tricky part of this job is installing the outer dirt seal. If you have a later model with the sleeve installed from the factory on the axle you will see that it has a taper at the sealing surface shoulder so it will slide into the seals without turning the lip of the dirt seal backwards. If you have this setup you can go ahead and insert the dirt seal into the housing with the lip facing out to keep the dirt out. If, however, you have an earlier model you should slip the dirt seal onto the axle shoulder sealing surface. Insert the axle into the axle housing. It will slip though the inner bearing and contact the gear. Rotate the axle until you feel the splines catch like they are lined up. At this point you will need to tap the axle in. If you have the later axle go ahead and insert it fully into the axle housing. If you have an earlier model and you have the seal installed on the axle, slide the axle in as far as you can and still be able to use a screw driver or flat bar to push the outer seal into the axle housing. Before pushing the seal in place install the washer and nut so you don't push the axle back out. Now pry the seal into the housing. Once the seal is in place you can insert the axle the rest of the way in and install the washer and nut. Tighten the nut and install the cotter pin and put everything back together. It is important that the lip of the outer seal is not turned backward or you will have a leak shortly because dirt will get into the oil seal. The parts you will need are 144752 inner seal, 570473 outer seal, and if you need sleeves on the axle sealing area they are 9616493 for the earlier models and 9824930 for the later models. I think the change was made in 1992 but if an axle was replaced it could have the later axle. It is easily seen if there is a sleeve installed on the axle.
