Bobcat  > Skid Steers  > BICS issues and sudden lock up of wheels/lift
 Author Thread: BICS issues and sudden lock up of wheels/lift
charlie12 is not online. Last active: 2/9/2011 9:20:13 PM charlie12
Posted: 02/09/2011 09:19 PM
Hope somebody can help. My 773 with 500 hours has been acting up. While in use, it would suddenly lock all the hydraulics up. I could restart and continue working. Now, it appears the problem is no longer intermittent, but permanant, and the only way I can move the bobcat is using the traction lock override. The error code is 11-05 which in the manual states "seat bar sensor short to battery". My first thought it is the seat bar sensor (which I have read about on this web site). Here is the wierd thing, when I move the seat bar up and down, the light on the BICS turns on/off as it should if the key is on but the engine is not running. If I start the engine, the seat bar light turns off(regardless of seat bar position), making progress impossible. I do not think this bobcat has a seat sensor. Any advice would be appreciated Thanks
Tazza is not online. Last active: 1/22/2015 7:37:48 PM Tazza
Re: BICS issues and sudden lock up of wheels/lift
Posted: 02/10/2011 02:36 PM
It could be a bad sender or even wiring has rubbed through causing a short. You're on the right track looking at the lights on the BICS box.
Try removeing the sensor and starting the machine, move a magnet around the sensor and see if the light comes on.
Rich M-37 is not online. Last active: 12/29/2012 7:31:19 PM Rich M-37
Posted: 02/11/2011 06:18 PM
If you donot have a set sensor, does it have a button that replaces it. On my 873 the seat sensor used to stick. When I went to Bobcat they asked if I wanted to upgrade to a button because the seat switch can be problematic. It was more money so I replaced the set sensor. If you have such an upgrade look at wiring for it. Rich M-37
Page 1 of 1
Forums  > Bobcat  > Skid Steers  > BICS issues and sudden lock up of wheels/lift
