Bobcat  > Skid Steers  > Re: bobcat 763 HP-3 light
 Author Thread: bobcat 763 HP-3 fault & Hydro oil temp light
teeroy is not online. Last active: 9/30/2010 4:51:41 PM teeroy
Posted: 08/17/2010 08:25 PM
on start up HP-3 code is on all the time, also the hydro oil temp warning light is on even on start up when oil is cold. i tried jumping the 2 wires on each sensor but it comes up with code 4 wiring short. is there a way to test the temp and pressure switch befor i get new ones?
Tazza is not online. Last active: 11/20/2014 1:48:51 PM Tazza
Re: bobcat 763 HP-3 fault & Hydro oil temp light
Posted: 08/18/2010 03:00 PM
Hook a pressure gauge up to the spot the sensor is screwed into. I would suspect its just a bad sender, they do go bad. The computer does detect open and short circuits, whats why you can't just jump it.
The charge pressure suould be about 90-120 PSI so get a gauge that will read at least 150PSI
Posted: 08/23/2010 03:48 AM
hey mate i hooked up a gauge no probs.. bought a new sensor but now im getting hp-3 hc-3 and think its hcf-1, all the wiring looks ok back to the black box under the cab. Is there somthing i can check before going back to the dealer? also with the lcd display when it shows the faults it shows 6o55 the zero is half size i think it means boss is this correct? or is this the hours..
Posted: 08/23/2010 03:08 PM
It does mean BOSS
I'm not sure what the issue could be. Have you harassed your dealer to see if they have any ideas?
Posted: 08/23/2010 03:13 PM
Thanks. do you know if there is a way to turn the warnings off to see the hours on the machine as it does not show them when it has faults come up? the dealer where i am is not much help they thought sensor or wire problem.. could it be the computer? troy
Posted: 08/23/2010 05:59 PM
I thought the hours would flash up first then the errors?
Its always possible its a computer issue, but as you did state when you shorted the sender out it showed as a short on the display. As its detecting this, its hard to believe its the computer....
Posted: 08/28/2010 05:27 AM
thanks for all the replys got it all sorted turns out it was loose or bad connections to the BOSS, all works the hours now show. troy
Goto to page:  Prev Next
Forums  > Bobcat  > Skid Steers  > Re: bobcat 763 HP-3 light
