fishfactor
- Jun 29, 2010
- 7
Hello everyone, newbie here. I just wanted to post a solution I came up with. If you own a bobcat T320 or similiar and use it with a forestry cutter, you know how aggravating it is to clean the radiator. On top of that, when you take the oil cooler out, you will probably knock a hole in the radiator. I've been operating this machine for almost 3 years with almost zero issues other than the radiator clogging up and knocking a hole in it when trying to clean it. I tried the "radiator savers" without success. So... after laying in bed at night thinking about the problem for a while, here is what I did in a nutshell. If you want specifics, let me know. I'm not trying to sell anything but if you are near Charlotte, NC and want me to do yours or help you, it can be arranged. I recently completed this and have ran the machine for a week in 100 deg weather with no problems at all. I removed the oil cooler and AC condenser. Shortned the brackets on the condenser so that it would sit on top of the radiator in the original rear mounts. I had to fab up some brackets for the front tabs to sit on because they will no longer reach the slots up front. Then I turned the oil cooler upside down modified the mounting brackets adding a hinged mount on the rear. Purchased, modified, and installed a radiator overflow tank off of a T170. Changed the angle of the rear cover so that it will clear the new increased height of the oil cooler. Now, I simply remove the rear cover, flip up the oil cooler which is on hinges, flip the condenser to the side, and clean the radiator. One person can clean the radiator in about 5 minutes. This is difficult to describe in words and I plan on redoing all of the brackets this winter when things slow down. Make some on the milling machine so they look more factory. I wish I had taken pictures, but it's too late for that.
