Hello, new to this forum, thought I would run this by some people that might have some experience with this tractor. A friend was handed the tractor down to him from a family member. Complained that it howled when trying to steer but boom and bucket hydros seemed to work fine. We drained the hydraulic fluid, replaced some hoses and o-rings that were leaking, and changed the 10 and 25 micron filters. Refilled with fluid, as per the manual he has. The problem seems to be only on the left side drive. The boom and bucket operate ok, and the right side drive seems ok also. The left side seems not very responsive, it doesn't want to move until you give it almost 1/3 stick movement, then it jerks and moves. Not smooth at all like the right side. Also if you try to move the left only, slowly, it will trip the filter light. When you are traveling at full foward, it also seems to walk to the left weak side. Any help would be appreciated.
