Other Topics  > Repowering  > Mustang 440 Motor
 Author Thread: Mustang 440 Motor
Bryan in Iowa  is not online. Last active: 9/2/2012 10:17:41 AM Bryan in Iowa
Mustang 440 Motor
Posted: 05/11/2010 05:56 PM
I just got an Older Mustang 440 . Motor is out of it , in pieces, some missing , cam and carb . It came with a motor out of some sort of a sweeper . It appears to be a Ford , it has a carter YF carb on it . It hasa coil pack rather than a distributor . There is some sort of a control box to control ignition . There is a three wire harness orange , red, and black , then there is a single black bullet connector about mid harness. If I can get this motor fired up , I 'll try puttin git in , looks like it should work . Otherwise I need to find another motor or parts to rebuild the original one . What kinda mess did I get myself into ? lol Suggestions ??? Thanks
Tazza is not online. Last active: 5/16/2013 5:42:56 PM Tazza
Re: Mustang 440 Motor
Posted: 05/11/2010 08:07 PM
I'd try and get the engine running first, see how you go from there.
The one that was in it is probably worn out, thats why it was in pieces...
Posted: 05/24/2010 11:02 AM
Well , I got the motor out of the sweeper to fire up and run . It is a 1990 ford 1.6 . Sounds good . Got wiring figured out . It same system they use on English Fords . Escort with 1.3 liter be be exact , very simple system . Gonna get some pics of progress on this project . Good clean up , then start swapping mounts and hardware etc. Thanks
Posted: 05/24/2010 03:00 PM
Looking forward to seeing lots of picures of this!
Posted: 05/28/2010 08:44 AM
Yes, me too! Always like a good swap story.
Posted: 06/06/2010 08:44 AM
Well ,his is turning into more of a headache than it looked like. The transplant motor ,although very similar in looks ,lacks many of the bosses and brackets the old motor had . Water outlet in different , exhast , gov mounting brackets etc. Gonna be a lot of fabricating ahead ! Looks like I'll be removing the engine /hyd pump craddle from loader . Then lining up new motor , building new mounts . Once thats done I can figure out exhaust , gov mount, and radiator hoses . Might be some Frankenstein plumbing going on ,lol .
bludorbronc is not online. Last active: 4/25/2013 7:19:16 AM bludorbronc
Top 100 Poster
Posted: 06/06/2010 10:03 AM
how easily is the motor going to line up with the pump. once that is done the rest is easy because that dictates where everything must go. i am using stock radiator, exhaust, alternator, breather, all had to be modified to fit when in put a 20r toyota motor in a bobcat. i have the ford motor out of it if you can use the parts. im in iowa also.
Posted: 06/09/2010 10:50 AM
Is it the inline 4 cylinder ? I'd sure lik emore info on in . Where are you located . Or if you'd like give me a call .319-329-0915 Thanks Bryan
Page 1 of 1
Forums  > Other Topics  > Repowering  > Mustang 440 Motor
